i560
VLAN Question
Sat Jul 12, 2008 2:21 am
I would like to use a rb450 as a layer2 switch by creating a bridge and add all the ports to the bridge. In a cisco switch I would just use one port as a trunk
example:
interface FastEthernet0/1
description Customer 1
switchport access vlan 164
switchport mode access
interface FastEthernet0/3
description Customer 2
switchport access vlan 165
interface GigabitEthernet0/1
description Trunk to Core Router
switchport trunk encapsulation dot1q
switchport mode trunk
Can I do the same thing with a mikrotik
use ether1 as Trunk, ether2 = vlan200, ether3 = vlan201
I have not been able to change the mikrotik's interface's default vlan.
Thanks,
mushmx
Re: VLAN Question
Sat Jul 12, 2008 8:23 am
Hello
Check this Link http://www.mikrotik.com/testdocs/ros/2. ... e/vlan.php
Maybe this help you.
i560
Re: VLAN Question
Sat Jul 12, 2008 3:15 pm
Thanks, I have already read the manual what I need is for all packets from ether2 to be tagged with vlan 200 and all packes from ether 3 to be tagged with vlan 201 and ether 1 to act as a trunk.
Chupaka
Re: VLAN Question
Sun Jul 13, 2008 1:39 am
so add vlan 200 and vlan 201 to ether1, and then bridge vlan 200 with ether2, and vlan 201 with ether3
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: brg3466, loner, mikrotikuserfree, Renfrew, snagles, trofiv and 184 guests
