sergejs
IPv6 firewall features
Wed Jul 16, 2008 4:21 pm
As you probably know IPv6 is slowly coming with all the new features and options. So it might be good time to look at things that are missing.
This time we would like to know what do you need in IPv6 firewall (filter,mangle) - What matchers? What actions? What IPv6 options?
omega-00
Re: IPv6 firewall features
Tue Jul 29, 2008 2:53 pm
Will IPv6 DHCP be available soon as well? :-)
- address-lists are useful currently, would be nice to have IPv6 address lists supported.
Also interested on how well the hotspot will cope with IPv6, assuming there is some upgrades required to the inbuilt DNS server to make it work with IPv6
Perhaps a mikrotik rep would care to put up a guide as to how to run a dual-stacked hotspot when the time comes?
gustkiller
Tue Jul 29, 2008 3:10 pm
...and a dual stack operation how to.
- ipv6 simple queues
- NAT-PT ( for make backwards compatibility with ipv4 destinations in a ipv6only network)
omega-00
Wed Jul 30, 2008 9:24 am
http://arstechnica.com/articles/paedia/ ... essing.ars - Article on IPv6 Firewalling (Interesting read)
Elvaelf
Sun Aug 03, 2008 11:13 am
Just mikrotik v3.x support IPV6?
A new guy of chinese it.
normis
Mon Aug 04, 2008 11:33 am
yes
andrewluck
Forum Veteran
Forum Veteran
Mon Aug 04, 2008 8:21 pm
I'll second the request for address lists.
Kind regards
Andrew
foobaz
Fri Aug 22, 2008 2:29 am
I'd like IPV6 DHCP and DNS.
roadrunner
Tue Aug 26, 2008 9:47 am
IPv6 ND (Neighbor Discovery) can be used instead of IPv6 DHCP
omega-00
Tue Aug 26, 2008 10:47 am
With IPv6 DHCP is mostly used to distribute additional information, such as DNS server addresses, although there will be a way to do this through router advertisements as well soon which may remove the need for it in some more locations.
roadrunner
Tue Aug 26, 2008 12:28 pm
I keep on forgetting that ND does just the basic addressing and that DHCP is still used for a lot of the rest of the informantion.
roadrunner
Tue Aug 26, 2008 12:49 pm
IPv6 firewall features:
- shortcut to match link local addresses easily
- optionally match items within a 6to4 tunnel so those packets don't bypass firewall rules.
- add address-lists like the ipv4 firewall has.
Other IPv6 features:
- 6to4 relay and Miredo/Teredo service
- Enable IPv6 for every service in RouterOS: hotspot, winbox, Dude, Userman, etc.
- PPPoE able to assign and route dynamic /64 blocks (out of a larger block) to PPPoE users.
omega-00
Fri Aug 29, 2008 6:24 am
+1 to the following:
cmartin
Sat Aug 30, 2008 8:46 pm
I would like to join with:
radvd (router advertising) functionality, which can simplify workstations configuration strongly.
sergejs
Mon Sep 01, 2008 3:13 pm
Address-list feature for IPv6 will be added in the next version.
As well there will be the following options,
*) hop-limit matcher;
*) hop-limit action;
*) icmpv6 matcher;
*) ipv6 extension header matcher.
Users browsing this forum: Kindis, zaina1 and 68 guests
