gregclemmons
DNS download?
Fri Jul 18, 2008 5:11 am
Can I download stat dns entries form one router and copy the to another? if so how?
Gregclemmons
pedja
Long time Member
Long time Member
Re: DNS download?
Fri Jul 18, 2008 9:57 am
There is no need to do so, just set one router to be slave dNS to other one. It will gather any DNS info from his master.
AigarsABCD
Re: DNS download?
Fri Jul 18, 2008 5:14 pm
/ip dns static export
Then copy the code and paste it in the other router.
pedja> and how do you do that in RouterOS?
iam8up
Re: DNS download?
Fri Jul 18, 2008 7:01 pm
Router1: DNS server with static entries
Router2:
set allow-remote-requests=yes cache-max-ttl=1w cache-size=10240KiB \
max-udp-packet-size=512 primary-dns=router.1.i.p secondary-dns=1.3.3.7
Set the clients to look at Router2 and if a client wants one of those static entries from Router1, Router2 will grab it from Router1 and cache it.
AigarsABCD
Re: DNS download?
Fri Jul 18, 2008 11:30 pm
But it is not a good idea because EVERY request will go through both routers (of course if not cached). It would be fine, if static entries change a lot, then you have to change only in router1, not both.
Anyway, gregclemmons asked just how to copy.
gregclemmons
Re: DNS download?
Sat Jul 19, 2008 3:03 am
Thnak you all!
I must get more into the terminal.. and not rely on winbox as much. I didn't relise export was available in terminal mode and not in winbox.
Thanks Again.
Users browsing this forum: Bing [Bot], EvGn, Google [Bot], telepro and 63 guests
