CanWAN
Load Ballancing in V3.13 code error
Fri Aug 15, 2008 10:28 pm
I am trying to follow http://wiki.mikrotik.com/wiki/Load_Balancing_Persistent
but when I enter nth=1,1,0 the router returns "invalid value 1,1 for packet, an integer required"
any thoughts ???
galaxynet
Long time Member
Long time Member
Re: Load Ballancing in V3.13 code error
Fri Aug 15, 2008 11:26 pm
CanWAN -
Sure - if you read the wiki - it is for ROS 2.9.xx You are using ROS 3.0
Nth is different under 3.0 First go look at the ROS3.0 'nth' presentation on the wiki. Mod the load balancing to match your needs, and remember 'nth' under 3.0 only takes two paramenters - not three like 2.9.xx
R/
Thom Lawless
General Manager
RapidWiFi, LLC
thom.lawless [at] rapidwifi.com
CanWAN
Fri Aug 15, 2008 11:32 pm
Found it, your a life saver... took some thinking to work out how to do the steps without using it twice, but the server seems to be using both ISP's now. THANKS Len
galaxynet
Long time Member
Long time Member
Sat Aug 16, 2008 12:57 am
You're welcome....
Thom
Thom Lawless
General Manager
RapidWiFi, LLC
duppini
Thu Aug 21, 2008 4:58 am
can you post all your configuration???
nat, mangle and routes
thanks
duppini
Thu Aug 28, 2008 6:42 am
hi, im using 3.13
nth with 4 wans and dont works fine
i dont know were is the problem
here is my configuration
add address=10.150.0.1/24 broadcast=10.150.0.255 comment="" disabled=no \
interface=LAN network=10.150.0.0
add address=10.113.0.2/24 broadcast=10.113.0.255 comment="" disabled=no \
interface=ether1 network=10.113.0.0
add address=10.116.0.2/24 broadcast=10.116.0.255 comment="" disabled=no \
interface=ether2 network=10.116.0.0
add address=10.117.0.2/24 broadcast=10.117.0.255 comment="" disabled=no \
interface=ether3 network=10.117.0.0
add address=10.112.0.2/24 broadcast=10.112.0.255 comment="" disabled=no \
interface=ether4 network=10.112.0.0
/ip firewall mangle
add action=mark-connection chain=prerouting comment="" connection-state=new \
disabled=no in-interface=ether5 new-connection-mark=uno nth=4,1 \
passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=uno \
disabled=no in-interface=ether5 new-routing-mark=uno passthrough=no
disabled=no in-interface=ether5 new-connection-mark=dos nth=3,1 \
passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=dos \
disabled=no in-interface=ether5 new-routing-mark=dos passthrough=no
disabled=no in-interface=ether5 new-connection-mark=tres nth=2,1 \
passthrough=yes
add action=mark-routing chain=prerouting comment="" connection-mark=tres \
disabled=no in-interface=ether5 new-routing-mark=tres passthrough=no
disabled=no in-interface=ether5 new-connection-mark=cuatro passthrough=\
yes
add action=mark-routing chain=prerouting comment="" connection-mark=cuatro \
disabled=no in-interface=ether5 new-routing-mark=cuatro passthrough=no
add action=masquerade chain=srcnat comment="" connection-mark=uno disabled=no \
out-interface=ether1
add action=masquerade chain=srcnat comment="" connection-mark=dos disabled=no \
out-interface=ether2
add action=masquerade chain=srcnat comment="" connection-mark=tres disabled=\
no out-interface=ether3
add action=masquerade chain=srcnat comment="" connection-mark=cuatro \
disabled=no out-interface=ether4
add comment="" disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
10.113.0.1 routing-mark=uno scope=255 target-scope=10
10.117.0.1 routing-mark=tres scope=255 target-scope=10
10.112.0.1 routing-mark=cuatro scope=255 target-scope=10
10.116.0.1 routing-mark=dos scope=255 target-scope=10
10.113.0.1 scope=255 target-scope=10
any ideas????
thanks
Users browsing this forum: abelardods, accarda, drjanson, eworm, N2B and 235 guests
