mushmx
Info byte and packet bug in ROS 3.13
Wed Aug 20, 2008 5:53 pm
Hi
I have install ROS V3.13 and I don't know what happening because in the NAT section I put a rule redirect proxy to port 8080 and the byte and packet info not increment :? the happend same into the filter rules not increment.
It is a bug?
Or I need change something to view the byte and packet incrementation?.
Chupaka
Re: Info byte and packet bug in ROS 3.13
Wed Aug 20, 2008 6:25 pm
post your /ip fi nat export
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
mushmx
Wed Aug 20, 2008 6:58 pm
This is my setting NAT
add action=passthrough chain=unused-hs-chain comment=\
"place hotspot rules here" disabled=yes
add action=redirect chain=dstnat comment="PROXY LAN-AKIWIFI" \
connection-limit=100,32 disabled=no dst-limit=1,5,dst-address/1m40s \
dst-port=80 fragment=no limit=1,5 protocol=tcp to-ports=8080
add action=masquerade chain=srcnat comment="masquerade hotspot network" \
disabled=no src-address=10.5.50.0/24
Chupaka
Fri Aug 22, 2008 1:59 pm
means 'redirect requests to proxy only if there are more than 100 requests from that user' =) remove all limits from the rule =)
mushmx
Wed Aug 27, 2008 6:26 am
Thank's for the reply :D
Users browsing this forum: meazz1, MSN [Bot], samwarez, victorsoares and 204 guests
