MUM Europe 2020
netikelis
ROS 3.13 cannot store settings in simple queues
Sat Aug 30, 2008 11:40 pm
Hi, i have problem in simple queues on winbox.
Ok, login to router , in simple queues page found columns: "name", "target address", "rx max limit", "tx max limit", "packet mark".
I add "RX" , "TX", "Total RX bytes", "Total TX bytes".
Disconect from router, connect again - "RX" , "TX", "Total RX bytes", "Total TX bytes" not show !!!
What problem ?
Sigis
Letni
Re: ROS 3.13 cannot store settings in simple queues
Sun Aug 31, 2008 1:14 am
Please verify that you are using the latest version of winbox. It can downloaded from here. http://www.mikrotik.com/download.html
Also, when connecting with winbox, make sure the "Load Previous Session" box is checked.
-Louis
InoX
Sun Aug 31, 2008 1:24 am
Same problem...is older than 3.13
parrini
Sun Aug 31, 2008 9:24 pm
Try the instructions on this thread:
http://forum.mikrotik.com/viewtopic.php?f=2&t=25433
Users browsing this forum: dad2312, Filament, mbovenka, pe1chl and 103 guests
