hrober
Radius PPPoE - Change queues dynamically
Thu Sep 04, 2008 5:30 pm
Using PPPoE and Radius, can I change/update a queue without disconnect the PPPoE Tunnel ? something like remove it and re-read the queue attributes, or all radius replies packets.
I know that is possible to write some scripts to remove queues, but my biggest problem is:
RouterOS will read radius reply again ?
Regards,
HRober
npbrasil
Re: Radius PPPoE - Change queues dynamically
Fri Sep 05, 2008 1:19 am
What's the radius type? Freeradius? If yes, freeradius don't support COA (Change of Authorization). You need COA for this function.
gyoztes
Sat Sep 06, 2008 10:35 pm
I can't answer to your question, but I'm interesting why do you like to do this. I use freeradius + mt for pppoe, and if any changes (for example anybody forget to paid), I send a "kill" signal to the mt from radius server. So what is the problem with log out and re-log in? I use session timeout with 24 hours, which is do it too.
gyoztes
hrober
Mon Sep 08, 2008 9:01 pm
I'm using freeradius as AAA server here. So, when I enable radius incoming on RouterOS, I can send some request to do some actions on RouterOS, right ? I can disconnect a PPPoE tunnel for example, using this strategy, can I send some request to RouterOS perform re-read Mikrotik-Rate-Limit attributes and renew the queues ?
I saw on docs the following statements:
RADIUS disconnect and Change of Authorization (according to RFC3576) are supported as well.
Mikrotik-Rate-Limit
http://www.mikrotik.com/testdocs/ros/2. ... radius.php
is there a way to extend freeradius to do it ?
Obrigado!
hrober
Mon Sep 08, 2008 9:15 pm
gyoztes
I intent to increase the bandwidth of my costumers all midnight/mid noon. I wouldn't like to disconnect them.
npbrasil
Mon Sep 08, 2008 11:40 pm
Hi hrober. In the current version freeradius don't support change of authorization, just packet of disconnection. You can disconnect the tunnel and on reconnect you can send the new attribute, but the disconnection is mandatory with freeradius (for now).
snark
Wed Nov 19, 2008 3:16 pm
maybe this helps
omidkosari
Trainer
Trainer
Thu Nov 20, 2008 5:50 pm
I think this one is best and exact you want http://forum.mikrotik.com/viewtopic.php?f=2&t=24224
mahdavi
Thu Jun 25, 2009 11:55 pm
Do you know , that NtTacPlus support change of authorization ??
Abolfazl Mahdavi
Software Designer & Developer
Microsoft Certified Technology Specialist
http://www.mahdavy.com
Users browsing this forum: Google [Bot], Google Feedfetcher, MarcDE, mohkhalifa, mszru, sbr and 92 guests
