KimC
Upgrading fron 2.9.x to 3.x - How to succeed every time
Sun Sep 07, 2008 12:36 pm
Hello
We have a lot of different RB's (age, type) with various versions 2.9.x. Before v3, we were normally upgrading as soon as this forum indicated that there were no major problems. With V3, it is another situation.
Many upgrade attempts from 2.9.x to 3.x has resulted in broken links, climbing, unbootable boards etc. Generally very unpredictable...
We have found one way to succeed every time. It is a little more complicated than normally, but it works 100 %. The requirement is a connection to ether1 on the board to be upgraded - either indirectly from a neighbor in the same tower, or directly with a pc at the end of the cable. The required steps are: 1) Reboot the RB, 2) make a backup and copy it to your pc, 3) make a "system reset", 4) copy the new firmware to the board, boot and make a "sys rou upg" and boot again, 5) Restore the backup.
Our conclusion is, that v3 is not always able to make the conversion of the custom setup from v2 on-the-fly. Luckily, the back-up/restore works well !
Please Mikrotik, fix the broken software !
sergejs
Re: Upgrading fron 2.9.x to 3.x - How to succeed every time
Mon Sep 08, 2008 10:53 am
Could you provide with more detailed information about the configuration, when upgrade from v2 to v3 isn't working on the fly.
enk
Mon Sep 08, 2008 1:23 pm
example: rb112 with RoS 2.9.46, 2.9.50 or 2.9.51. Hotspot service configured. I have provided some details in e-mail for support.
as known as shados.
blog: http://betep.wpl.ru
A karma increase would be cool if you think I earned it.
normis
Mon Sep 08, 2008 1:28 pm
please avoid using "Servers" on RB112, it's not meant for that purpose. It's just not so powerful to work as a hotspot server. It's a CPE.
sergejs
Mon Sep 08, 2008 2:18 pm
enk, there are not too much details.
What do you see in the logs after upgrade ?
Are there any console output after 'system reboot' ?
enk
Mon Sep 08, 2008 4:10 pm
00:00:17 system,info installed routeros-mipsle-3.13
00:00:21 system,info enabled routing-3.13
00:00:21 system,info router rebooted
00:00:34 system,info,account user admin logged in via local
00:00:47 system,info filter rule added
00:00:48 system,info nat rule added
00:01:03 system,info hotspot walled-garden rule added
I was mistaken about resources, processor load at 0%, but the memory seems to be lacking.
[admin@test] /system resource> print
uptime: 3m33s
version: "3.13"
free-memory: 2336kB
total-memory: 13840kB
cpu: "MIPS 4Kc V0.11"
cpu-count: 1
cpu-frequency: 175MHz
cpu-load: 0
free-hdd-space: 32580kB
total-hdd-space: 61440kB
write-sect-since-reboot: 240
write-sect-total: 515995
bad-blocks: 2
architecture-name: "mipsle"
board-name: "RB100"
copied to support email.
as known as shados.
KimC
Wed Sep 10, 2008 11:38 pm
We can't see any pattern. The problems has been with many RB532 of different age and hardware version. However, it seems to be worse with a more complicated set of firewall and mangle rules. All units are with wireless interfaces (a mix of mt-cards and various ubnt cards in g/a/a-turbo).
But my point is: Backup/restore works and the upgrade conversion fails ! You can only be sure to succeed an upgrade, when a routerboard is in the factory default state.
Regards
KimC
Equis
Forum Veteran
Forum Veteran
Thu Sep 11, 2008 1:43 am
I have just upgraded about 500 cpe's to v3.11
I did not loose one.
I did not have hotspot or anything, just basic cpe packages.
Perhaps 5 wedged and needed to be power cycled but all came up :-)
KimC
Thu Sep 11, 2008 1:03 pm
Well, a CPE setup is not exactly our typical setup. It is very close to a factory default.
We are using MT for infrastructure only. I would like to hear from experienced users with installations beyond "vanilla" setups, using wds, nstreme, bonding, firewall, nat, multiple ip, routing, dns-cache, multiple wireless interfaces etc etc..
I simply don't believe, that we are the only ones with these problems.
Users browsing this forum: Baidu [Spider], ebash43, humbfig, Prometeo and 84 guests
