MUM Europe 2020
zytus
IPTV and igmp proxy
Fri Sep 12, 2008 1:43 am
Hello
My ISP does not provide to users PIM with RP IPTV, only solution: to see IPTV with router igmp proxy feature, for example on popular router linksys is option Enable multicast (it is igmp proxy option) and after I create port forward UDP 5000 to one local lan PC, only after it i can see IPTV with vlc or friptv.
How configure (if its possible) Mikrotik with igmp proxy, now I have Routerboard 433AH with Mikrotik and how to see IPTV without PIM RP?
mrz
Re: IPT and igmp proxy
Fri Sep 12, 2008 10:01 am
You can try to forward UDP 5000 port to local PC and see if it works.
zytus
Sat Sep 13, 2008 4:33 pm
If I forward UDP 5000 - no results...
I think in mikrotik must be igmp proxy feature.. I don't know are this feature implemented or not... Can anyone run iptv from ISP with mikrotik without PIM ?
ALCOOL
Re: IPTV and igmp proxy
Wed Oct 22, 2008 12:20 am
same problem
any solutions? possible solutions?
ALCOOL
Sat Dec 27, 2008 9:16 pm
Can't believe that it's impossible!
When i use dd-wrt i don't need to touch any settings, but i can't use MT.
mrz
Mon Dec 29, 2008 8:55 am
latest RouterOS version has IGMP proxy support.
ALCOOL
Mon Dec 29, 2008 9:34 am
I use 3.17, it has igmp proxy.
But i can't make it work.
May be i need another version?
janisk
Tue Dec 30, 2008 1:33 pm
post your configuration, i have done PIM-SM forwarding using igmp-proxy - worked like a charm
ALCOOL
Wed Dec 31, 2008 12:16 am
May by you should post your config? Mine is nor working..
I have "wan" interface, pppoe on this interface, masquerade on both.
iptv is on the wan interface.
povider presents .vlc playlist with smth. like this inside:
udp://@224.0.42.69:5000
udp://@224.0.42.81:5000
so, i also has "LAN" iface, where my PC with VLC player is located.
I tried different settings, but it isn't working.
Please, help! :)
janisk
Fri Jan 02, 2009 12:11 pm
check this page, i should become more clear, where you have to set up what for IGMP-proxy to work.
http://wiki.mikrotik.com/wiki/IGMP-Proxy
ALCOOL
Wed Jan 07, 2009 2:01 am
I tried
[admin@MikroTik] /routing igmp-proxy> interface add interface=ether1 upstream=yes
[admin@MikroTik] /routing igmp-proxy> interface add interface=all
but
[admin@MikroTik] /routing igmp-proxy> interface print
Flags: X - disabled, I - inactive, D - dynamic, U - upstream
# INTERFACE RATE-LIMIT THRESHOLD
0 IU CPMS 0 1
1 I all 0 1
How can I check if something is wrong?
janisk
Wed Jan 07, 2009 4:09 pm
better add separate interfaces, so you have more control over what is doing what
for testing purpose, you can make some multicast traffic (PIM-SM) and check if it gets correctly through igmp proxy (data stream)
ALCOOL
Wed Jan 07, 2009 4:19 pm
how?
feell myself silly..
janisk
Wed Jan 07, 2009 4:25 pm
I tried
but
0 IU CPMS 0 1
1 I all 0 1
as you see in print, interfaces are marked as Inactive - means, nothing is working.
that one is correct
/routing igmp-proxy interface add interface=ether1 upstream=yes
like that you should be able to add more interfaces
/routing igmp-proxy interface add interface=ether2 upstream=no
check if all interfaces have ip address assigned.
ALCOOL
Wed Jan 07, 2009 4:38 pm
i have rebooted router, and interface are not inactive now.
But nothing works.
in log I can see:
igmp-proxy info_starting IGMP proxy forwarding
and a lot of messages like this:
igmp-proxy warning_ignoring IGMP message: received on the upstream interface
igmp-proxy warning_ignoring IGMP message: group is not a multicast address
igmp-proxy warning_ group=0.0.0.0
tolstii
Trainer
Trainer
Sat Apr 11, 2009 6:18 pm
The problem has dared? If yes that as?
ALCOOL
Wed Jul 22, 2009 12:10 am
it works.
the solution was to reboot router after every step :)
but now another problem - mt doesn't leave tv channels.
I 'm changing channel on vlc, but mt doesn't leave previous. So after i change 3 channels, everything stops - 3x3.5MB for every channel
janisk
Wed Jul 22, 2009 12:21 pm
set quick-leave=yes, then channel swaping will occur faster, as special leave packet will be sent the moment you switch, other way you have to wait for timeout.
ALCOOL
Wed Jul 22, 2009 1:07 pm
i tried 00:00:01 in both cases. nothing changed.
timeout is about 5-7 minuts.
janisk
Wed Jul 22, 2009 1:58 pm
and any results with quick-leave?
in my tests IGMP group was left almost immediately.
mehanik
Thu Sep 06, 2012 6:48 pm
sajjadsdk
Wed Jan 07, 2015 5:50 pm
Dear Friends i configured IPTV with IGMP Proxy.. Iptv started working with all clients that are connected on hotspot or pppoe server. But now another problem occured. When iptv runs in vlc or app the internet stopped working with some clients and hotspot page doesn't appear in the browser and internet service break down and iptv started run.. How to get both traffic without any problem. Did any one knows about it.
My configurations is :
IGMP PROXY
Upstream on WAN interface subnet 0.0.0.0/24
and add another interface LAN without subnet
sajjadsdk
Mon Jan 19, 2015 7:13 am
Same problem here. when i run iptv on same lan on which hotspot and pppoe running my internet stopped working with clients and iptv started working.
Users browsing this forum: Davis, gkk, MSN [Bot] and 124 guests
