spavkov
2 ISP-s (gateways,IPs) for one Mikrotik routed network ???
Sun Apr 10, 2005 11:03 pm
Hi!
I have one ISP and they gave me one public ip and default gateway...
but now i have one more ISP for test only...
how can i use both of them???
in this situation i will have 2 public ip's and 2 dafault gateways...
i have 70 wireless hotspot users on 10.5.50.0/24 prism interface and this network is masqueraded to first ISP ip (80.74.XXX.XX)
how can i use both ISP??? can i have 2 public IPs and 2 DEFAULT GATEWAYS..
only to make something clear: both ISP-s will come via one ethernet cable (i will recieve them over one ethernet NIC)
i know its sounds strange but its true! :)
please help
blue
Mon Apr 11, 2005 12:21 am
The simpliest way is to "split" your users to two groups and then use routing tables to tell each user/group what gateway/isp to use. The solution with entering two gateways to complete lan is not working well...
spavkov
Mon Apr 11, 2005 1:45 am
Tnx
ili HVALA !!!!
poz
Slobo
djordjez
1 LAN 2 WAN
Mon Apr 11, 2005 4:05 pm
I have 2 gateways as well.
You just have to make a new route dst-adr=0.0.0.0/0 gateway=1st ISP, 2nd ISP
ili na srpskom ja imam dva izlaza koja se natuju. Stavis default rutu na oba i radi super
Pozdrav Djole
spavkov
Mon Apr 11, 2005 5:39 pm
odlicno, probacu i to...
Hvala na pomoci!
blue
Tue Apr 12, 2005 12:54 pm
Au, sta je ovde ljudi sa naseg govornog podrucja :D
A sada malo na engleskom
I have tryed to use two gateways, but packets get lost somewhere. I had a lot of packetlosses with that solution so have to use two diferent gateways.
djordjez
Wed Apr 13, 2005 3:31 am
Gde ima nesto jeftino a dobro tu su i Srbi. Imam malu ispravku na moj prosli post umesto reci nat treba da stoji masquarade.
In my last post there was a mistake. Instead of nat should be masquarade.
All the best, Djole
pedja
Long time Member
Long time Member
Wed Apr 13, 2005 5:03 pm
Sta mislite o tome da napravimo neko mestasce gde bi smo mogli da pricamo na srpskom?
normis
Wed Apr 13, 2005 5:13 pm
please use english on the forum, so that others also can understand your conversation :)
spok
Wed Apr 20, 2005 1:58 am
HHi hhee
Pa mogli bih da naparvimo jedan POST " MIKROTIKOVCI " i da spikamao na srpskom :))))
Users browsing this forum: Bing [Bot], che, insel and 204 guests
