danielillu
Compact Flash RouterOS not bootable
Thu Oct 16, 2008 11:19 pm
I have a spare Level 5 compact flash I recovered from a fried board.
One I recovered it, it booted correctly, so I installed in there some now old RouterOS version and stored it.
Today I was messing around to mount a lab-machine to test some features using that card but I didn't boot.
I tried netinstall, detected it correctly, got the license, reinstalled 3.14, rebooted, and didn't boot.
PC hangs waiting for "Insert system disk and press enter".
Could I grab a linux box, mark boot partition as active-bootable and get it working? or I've just lost it forever?
danielillu
Re: Compact Flash RouterOS not bootable
Thu Oct 16, 2008 11:36 pm
Nah, Lost forever.
During POST appears:
- "Primary master drive fail"
What should I do?
GuJack20
Trainer
Trainer
Thu Oct 16, 2008 11:43 pm
Maybe contact support??
--Do you remember that guy who gave up? Neither does anybody else!
changeip
Fri Oct 17, 2008 1:01 am
is it only the new pc that wont boot from it? Maybe the BIOS isnt correctly setup for flash. Sometimes you need to toggle CHS/LBA, or AUTO vs actual parameters, or other IDE settings. Is it on primary or secondary IDE ?
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
danielillu
Fri Oct 17, 2008 10:41 am
I tried on the two computers I had available. Both were running from CF so they were correctly configured.
I set up everything on "AUTO" but didn't work.
As I told, BIOS error stands for: "Primary master disk fail". I tried also on primary slave and then stated "Primarry slave disk fail".
acim
Fri Oct 17, 2008 1:31 pm
Probably not compatible motherboard (S-ATA controller). What chipset do you have on your motherboard?
Try to put flash in some older PC.
Users browsing this forum: Google [Bot] and 106 guests
