karo84
Router OS 2.9.51 Crashes every day
Sat Nov 01, 2008 12:53 am
Hello
My Router crashes almost every day
with such problem unregistered net device ...
and it begins to reboot for 5 minutes or often untill I switched of power.
what is going on?
I do not want to upgrade to 3.1X because of PPPTP and PPPOE DIE issue.
who can tell me what can I do,
Any suggestions or advice?
jwcn
Re: Router OS 2.9.51 Crashes every day
Sat Nov 01, 2008 1:50 am
What kind of hardware are you using?
karo84
Sat Nov 01, 2008 2:42 am
Caci99
Sat Nov 01, 2008 3:12 pm
Sounds like a watchdog reboot.
Have you checked log file?
-Toni-
Don't crash the ambulance, whatever you do
karo84
Sat Nov 01, 2008 5:17 pm
Log does not tell anything,
only when I click to open new terminal the above mentioned error is appears.
roc-noc.com
Forum Veteran
Forum Veteran
Sat Nov 01, 2008 5:46 pm
It sounds like a hardware problem. Have you tried to isolate it by moving the hard drive to another PC?
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
karo84
Sat Nov 01, 2008 7:41 pm
We have changed the router PIV > PIII IBM
and it works fine, but here the cpu is always ~ 60% used.
InoX
Sat Nov 01, 2008 9:48 pm
so? it's not 100%
karo84
Sun Nov 02, 2008 1:27 am
No Yet, But soon it will be 100%, as the number of my users grows.
InoX
Sun Nov 02, 2008 12:32 pm
Buy another PC and try.
karo84
Sun Nov 02, 2008 1:18 pm
I have changed already 4 PC all they were PIV but no difference.
Only difference was the interval of crash.
jwcn
Sun Nov 02, 2008 10:16 pm
How many users? How much data?
karo84
Sun Nov 02, 2008 10:25 pm
Up to 10 Mbps, and I am going to enlarge that bandwidth.
I'd like to know what Motherboard could you advice to use.
Caci99
Sun Nov 02, 2008 10:27 pm
It still sounds like a hardaware problem so in etheir way or other
I think you need to check your hardware, may be your HDD?
We have one RouterOS version 2.9.50 installed on a computer
Pentium III 400MHz, and isn't causing any problem, nor CPU load.
We have simple queues running on this machine and time to time
we use it as Proxy for testing also.
As for motherboard, I think IBM with intel chipset are very steady
-Toni-
InoX
Mon Nov 03, 2008 4:34 am
I've had:
1.P3 1Ghz with i815
2.Duron 1.8Ghz on Gigabyte with KM266
3.P4 2.4Ghz
4.AMD X2 Gigabyte (nVidia chipset)
they all worked, I think you should check ypur configuration ar change the LAN card's.
Users browsing this forum: No registered users and 64 guests
