cravetou
full squid feature with GUI in mikrotik will be great
Sun Nov 09, 2008 9:07 pm
the web proxy with mikrotik now is very simple its great if mkiortik develpers team give us a full squid feature with GUI for configuration
squid + mikrotik = linux kernal
Equis
Forum Veteran
Forum Veteran
Re: full squid feature with GUI in mikrotik will be great
Mon Nov 10, 2008 8:02 am
+1
I am not sure why Mikrotik need to reinvest the wheel on this one with their own Proxy.
Squid is a perfect solution.
cravetou
Mon Nov 10, 2008 8:54 am
me too dude i dont knew why they do this great improvment even all mikrotik feature is great expact its proxy
ask normis foooor that
normis
Mon Nov 10, 2008 9:12 am
2.9 has squid
cravetou
Mon Nov 10, 2008 11:04 am
dear normis
it has but limited squid not full feature we need to use great feature of that great squid with great mikrotik all of us are Tired from use external squid box and patch with zph and and ...!!!! it s very cool if routerOS 4.x come with GUI squid feature
again i wish that
normis
Mon Nov 10, 2008 11:05 am
RouterOS is not a cache server. It has cache for convenience sake
Equis
Forum Veteran
Forum Veteran
Tue Nov 11, 2008 5:26 am
I think router OS should be just a router (with wireless support) but allow "plugins"
So you can plugin squid/bind etc and have access to the full squid.conf file etc.
It should be stated that Mikrotik does not support plugins etc but you can use at your own risk.
Edit: was not my idea but another persons, I'm just bringing it up again :-)
cravetou
Tue Nov 11, 2008 10:09 am
this is a good idea even we can pay for addtional feature like full squid
what did u say normis???
jp
Long time Member
Long time Member
Tue Nov 11, 2008 5:54 pm
If you want a higher end/higher featured squid box, you have to put the work into it. If the linux part is too much trouble, try a different linux distribution or learn more linux stuff. I've got two linux boxes running squid that are much more reliable than a typical MT. Webmin can handle squid too, but I've never tried it.
jp@xj13:~> ssh saucer uptime
Password:
 10:50am  up 1005 days 18:01,  1 user,  load average: 0.04, 0.07, 0.01
jp@xj13:~> ssh lbs uptime
Password:
 10:50am  up 1049 days 19:27,  0 users,  load average: 0.00, 0.00, 0.00
jp@xj13:~>
Mikrotik has plenty to do besides reinvent squid so it works a different way for our convenience.
janisk
Mon Nov 17, 2008 2:25 pm
as far as i can remember decisions that where made - that if you need full featured proxy server then make one, that is why RouterOS have "Parent proxy" feature that will forward proxy requests to parent proxy, powerful and highly adjustable server with SCSI raid for cache etc. while RouterOS have small and easy to configure proxy server build in, for basic user needs. Thas was so because RouterOS is made for routing not for everything you need, we don't call it Mikrotik OS
normis
Mon Nov 17, 2008 2:28 pm
name one feature that you want in RouterOS Proxy that is in Squid, but MT Proxy doesn't have.
Please no "full squid" because it's just not realistic. Let's make a questionnaire
cravetou
Tue Nov 18, 2008 8:04 am
Questionnaire its good idea
i needs MT proxy to cache some page that come with (no cache) directive and i want to specify the amount of time that the file should be valid for specified files and other ....
i can say additional full feature squid package for routerOs that can we buy it for additional cost just for x86 or AMD to accommodate the squid needs
Its gonna be great
Equis
Forum Veteran
Forum Veteran
Tue Nov 18, 2008 10:29 am
No offense intended but an uptime of longer than 3 days under load (700+ customers) would be great :-)
omega-00
Fri Nov 21, 2008 3:18 am
I vote for the same thing, the proxy needs to be more stable, specifically in relation to the hotspot system.
I personally run my own mini-proxy on my home connection using a 4gb usb drive with no problem, however I still see our larger sites (500+ user) fall over due to the proxy issues from time to time and the only guranteed fix I've found is to downgrade or upgrade the router, then revert back to the original version (which is v3.13)
normis
Fri Nov 21, 2008 9:30 am
there we go - everyone asks for Squid, but when I ask a simple question - no answers. Stability is no issue here, we had Squid before in v2.9 and it was practically the same. Can someone name a feature please?
Equis
Forum Veteran
Forum Veteran
Fri Nov 21, 2008 9:36 am
I am not after any more proxy features.
I'd just like to be able to have a large stable ram cache on my router pointing to a larger upstream proxy.
I wonder whey squid was not stable in 2.9 as you say?
I find a Linux box with squid see's huge uptime under load.
I find Mikrotik proxy under load is not so great, I've written to support etc, they say they have not been able to test under that kind of load.
normis
Fri Nov 21, 2008 9:48 am
I didn't mean it like "just as unstable". I wonder why you have instability issues with current ROS proxy - have you worked with MT support on this?
Equis
Forum Veteran
Forum Veteran
Fri Nov 21, 2008 10:50 am
I did speak to support but was unable to work with them, I could not afford to have my ISP stop every few days and need to drive done to reboot the system.
I had the same problem others mentioned here.
I never have used the 2.9 proxy so I can't compare the two.
normis
Fri Nov 21, 2008 11:05 am
It's very hard to fix something that we have never seen, and that you refuse to show us :(
Equis
Forum Veteran
Forum Veteran
Fri Nov 21, 2008 11:09 am
Can you understand why I can't afford to show you?
normis
Fri Nov 21, 2008 11:10 am
Yes. But if everyone has these same reasons, we can't do anything
Equis
Forum Veteran
Forum Veteran
Fri Nov 21, 2008 11:20 am
I agree, it would be frustrating for you.
If MT wanted I could enable and create the output file every hour, perhaps this would give clues.
omega-00
Mon Nov 24, 2008 3:07 am
normis: I've also sent through a number of supout.rif's and also participated and provided information to a number of other users who were also affected.
See - http://forum.mikrotik.com/viewtopic.php ... t&start=50
How to replicate the problem yourself: Turn on transparent proxy and get 100 or more users to start using. Thats probably the easiest way to force it to crash. Alternatively you can put 500 users on a proxy without the transparent proxy turned on, then wait for 2-6 weeks for it to randomly crash (murphy's law means it's normally around 12 at night :-) ).
SkullKill
Mon Nov 24, 2008 12:06 pm
i can vouch for the problem describe by "omega-00". very frustrating problem, given the fact that downgrading/upgrading and reverting back "Sometimes" "Fix" the problem, for a while, untill it occurs again....
vdeluca
Tue Nov 25, 2008 2:06 pm
feature suggestion that was available on previous versions, and removed on 3.x
Max object size:
Other suggestions: Use memory to stores metadata from the objects on cache, to speedup the access on disk.
Squid box for 150gb cache, is recommended at least 2g ram.
On my MT cache box, I´m almost 200gb full cache, but the memory used on router is very low.
I can imagine that seeking hard disk (sata) in this case takes a lot more of just querying the metadata and previously know where the object is.
best regards,
vince de luca
omega-00
Thu Dec 04, 2008 7:57 am
I have to say: When just used as a caching proxy server for a small number of users the proxy does work fine for me.
I currently have a 4gb proxy running of a usb drive on my mikrotik, currently using v3.16 with no problems, however if I try the same thing with any of my hotspot sites with lots of users (200+) and the transparent proxy turned on I see issues normally within 24 hours.
With the transparent proxy turned off I have systems running for up to 2 months maximum without seeing any issues.
On sites just using other router functionality I have uptimes of 4 months and more on v3.X with no issues
mojiro
Sat Dec 06, 2008 1:33 pm
Since it is/was real Squid, why not to support proxy-mesh and so many other features that squid does ?
Why configuration options are so poor ?
At last give the opportunity to upload squid.conf inside mikrotik :)
Deep to cloud!
Chupaka
Sat Dec 06, 2008 5:31 pm
Thats because RouterOS is RouterOS, not ProxyOS or SquidOS!
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
mojiro
Sat Dec 06, 2008 5:46 pm
I agree but, using that logic, it shouldn't have proxy at all.
My notice has to do with poor options in general. Do you want another example ?
-> Why TCP/UDP option is missing from OpenVPN ? It is just a line in the configuration file...
Deep to cloud!
normis
Mon Dec 08, 2008 9:46 am
specifically for this case, did you send a supout.rif file to support? in any case, please make a new ticket and send some files. we will see what we can do
omega-00
Wed Jan 14, 2009 9:00 am
Hello Normis,
Just sent through another supout.rif regarding the proxy issue (which is now affecting v3.18)
Ticket number is 2009011466000074
Regards
Omega-00
msundman
Sat Feb 21, 2009 12:57 am
Hello Normis,
Has this problem been resolved yet or are you still experiencing these problems with v3.20?
When you guys have problems with the proxy, is it enough to disable/enable the cache to have it start working again or is a complete reboot neccesary?
I'm just wondering because I'm just about to put an RB1000 in production in a rather big corporate network to be the default gw and also use it as a forwarding proxy and I really really don't wanna have to reboot this device just because the proxy has a problem. Then I should get them 2 boxes right now and run the proxy forwarder in a seperate now that can be rebooted without affecting the normal routing out of the network.
omega-00
Sun Feb 22, 2009 4:00 pm
Have yet to see any instances of that bug in 3.20 which I'm currently running at a site with 1300~ users spread over 2 devices.
Looks like its all good for that version.
Users browsing this forum: No registered users and 101 guests
