airnet
RANT - Configuration management: .backup is a joke
Wed Dec 10, 2008 10:49 am
<rant>
I am sure this has been ranted about many times before but here goes again:
WHY WHY WHY is MT STILL using a binary .backup system ?
Why do we not have a good old startup-config.txt and running-config.txt based system yet ?
*most of the time* a generic .backup file breaks wireless so this means a remote site visit.
Mass upgrades are EXTREMELY COMPLICATED and NEAR IMPOSSIBLE with the existing .backup compiled binary backup system.
Many of you will say, 'but my upgrades work fine'. Yes that is true MOST of the time. But the problem is due to the fact that new versions always have something broken, so most of the time it ends up getting rolled back.
Try doing that to 1000 remote wireless CPE's automatically.
There seems to be a race to add new features whilst accidentally breaking existing features in the process. It happens with almost every release.
The other huge problem we see is upgrading from 2.9 to 3.x. Approx 20% of the units upgraded have a 100% CPU issue post-upgrade. The ONLY solution is to system reset and manually reconfigure. End config / net result is the same but no high CPU drain this time. The binary .backup thing is utter and total junk and subject to corruption between upgrades / downgrades.
If we had a .txt based system none of this would be a problem, and I could automatically push out a mass upgrade to 1000 CPE's in under 5mins, AND get some sleep for once.
</rant>
normis
Re: RANT - Configuration management: .backup is a joke
Wed Dec 10, 2008 10:54 am
this is why you have the wonderful Export.rsc files, that can be:
- human edited
- generated by excel/calc
- scripted
- used as "default config" after "system reset"
- etc ;)
janisk
Wed Dec 10, 2008 11:13 am
What's new in 3.0rc3:
*) ftpd - automatically execute uploaded scripts that have name *.auto.rsc;
meaning - you have to upload script file using ftp (no other upload will work) and it will be automatically executed
script looks exactly as if you did export of configuration.
for example:
 /ip address add address=192.168.1.1/24 interface=ether1
will add an ip address to router you upload that file.
airnet
Wed Dec 10, 2008 11:28 am
I guess I should retract most of my rant...
Thanks.
changeip
Wed Dec 10, 2008 7:06 pm
it wasnt mentioned here, but typing "export" at any node in the CLI will export that configuration in plain text.
type export at the main level and everything will be exported.
type export file=config it will export to a file called config.rsc.
Sam
airnet
Wed Dec 10, 2008 7:52 pm
- human edited
- scripted
- etc ;)
Normis - Please elaborate on how to do execute .rsc after system reset when no remote comms is possible due to system being reset...
I cannot find any documentation on this.
airnet
Wed Dec 10, 2008 7:56 pm
ChangeIP, full exports are a good text reference only. I have never had any luck importing a full export - only small export 'snippets' work 100%.
Or what am I missing here ?
Cheers
normis
Thu Dec 11, 2008 9:08 am
Cheers
you have to modify them, remove all things that you don't need to import. leave only important stuff, and in logical order.
currently you can give Netinstall an RSC file when installing/reinstalling RouterOS, and that will be used when doing system reset.
janisk
Thu Dec 11, 2008 9:39 am
also, if you use xen (highly experimental) you can see, that when you create new guest you can supply rsc file, that way you can see, how it will look like, when you use it in normal RouterOS install (to test out script)
or import that script into clean router and see result.
airnet
Thu Dec 11, 2008 1:05 pm
Bummer... we're talking LOTS of 133's already deployed remotely and wirelessly. The nearest is 1km away. The farthest is 500km away. Netinstall is out of the question. They are all running 2.9.x
The objective is to upgrade them all to 3.02 in a CLEAN MANNER. Eg system-reset then upgrade then configure.
3.02 is actually labelled 3.2 - this is the only stable version 3 that runs on 133's we have found from experience.
ALL later 3.x versions are broken when running wireless and PPPoE client on a 133. It's the PPPoE client that kills the 133. Not only does PPPoE client overload the CPU, but NAT is also broken in all the latest releases.
The reason that 3.x is required is for WMM. Yes, WMM works fantastic too. But it only works without nstreme.
Back on topic..
I guess my rant still stands then:
There is no simple CLEAN way to automate the upgrade of already deployed wireless 133 CPE's for the purpose of activating WMM ?
Plan B: How about the MT guys create a WMM backport for 2.9 ?
eg wireless-test-2.9.51.npk that includes WMM ?
As I understand WMM is done in the Atheros chipset. The O/S only has to set a 'flag' to enable it. Surely this is possible ?
janisk
Thu Dec 11, 2008 2:00 pm
i wondwer - how you imagined to access the board after you clear all the configuration that is there? If you have other routerboard near by in same ethernet network you can reset-configuration and then connect using mac-telnet from that box and set up configuration.
airnet
Thu Dec 11, 2008 11:44 pm
Thats the exact purpose of this thread. I want to be able to completely reset, reconfigure and upgrade in one hit WITHOUT having local access.
The reason this is a rant is because industry standard dictates a startup-config and running-config text based configuration system, to avoid all of the problems we are discussing here.
This is a fundamental feature that MT should have, but currently does not.
Gerard
Trainer
Trainer
Fri Dec 12, 2008 5:19 am
I would love to see the export command export only the values that are changed from their default value.
At the very least have the export be able to be imported back into a defaulted router without having to edit it.
It's very frustrating to say the least how it is handled right now.
-Gerard
dot-bot
Fri Dec 12, 2008 5:58 am
I agree with Gerard. I have spent days in editing rsc and txt.
normis
Fri Dec 12, 2008 8:51 am
If the router hardware is different, it's very hard for ROS to know which addresses need to be applied to which interface, which wireless cards should be used etc. And then there are different drivers and so on.
Although I agree, we need to improve this function so that at least it could be imported back to the same router.
But actually there is no "import" it just executes all the commands in the file.
janisk
Fri Dec 12, 2008 12:12 pm
also, i would like to note, that you had a chance to set up default load configuration before you installed router in place in some obscure place using netinstall tool as noted before in this thread.
as normis said - that functionality could be improved.
normis
Fri Dec 12, 2008 1:34 pm
Would a "/system reset-configuration file=name.rsc" do what you want? It would reset, and then apply the config in the RSC file so that your CPE could connect to the AP for example.
airnet
Sat Dec 13, 2008 2:15 am
Normis - yes this would be perfect in the long run. In fact, I was just about to suggest this in an email to support@mikrotik....
The downside for us right now is:
1) Most of our CPE's are 133's and the only known 'reliable' v3 build is 3.2 (3.02) on this platform. So I think this is our only option*
2) They are already deployed and would need to be upgraded to get this feature if it was to be added.... it's a catch 22.
*how about a backported system_with_restore_config_patch-3.2-mipsle.npk :D ?
Cheers
airnet
Sat Dec 13, 2008 2:19 am
All MT Routerboards arrive from factory with RouterOS pre-installled.
However, in knowing what we know now, we would have indeed re-installed using netinstall prior to deployment...
jp
Long time Member
Long time Member
Sat Dec 13, 2008 1:17 pm
That would be a great feature!
gbh
Sun Dec 14, 2008 2:02 am
that feature would have made my life much more enjoyable if implemented recently..
cmit
Mon Dec 22, 2008 2:47 pm
That would be a BIG improvement over the current status!
maximan
Trainer
Trainer
Mon Dec 22, 2008 8:53 pm
+1, this could be great feature.
M.
missinlnk
Mon Dec 22, 2008 9:44 pm
Sorry to just join the bandwagon, but I know this feature would be loved by several of our customers. Not having to do a netinstall to change that file would be wonderful.
Kry0h
Fri Feb 27, 2009 11:21 pm
Any news about this "feature" ?
Im very interested on this particulary situation, many of my nodes are very hard to get there .. some of them are on the top of buildings that i dont have the key :P , in fact right now im facing this situation with one of my rb133 :?
Muzaki
Mon Jun 08, 2009 11:34 am
Would love this, but still nothing?
femur
Mon Jun 08, 2009 2:41 pm
We still dream about this future, Normis!
or I have alternative elegant solution. You can simply implement to run files:
auto-after-reboot.rsc
auto-after-reset-configuration.rsc
is it really hard to code this?
femur
NAB
Trainer
Trainer
Mon Jun 08, 2009 4:11 pm
Silly question, but wouldn't this value be reset along with the rest of the unit? If not, how does one make sure it is reset if one so desires?
normis
Mon Jun 08, 2009 4:13 pm
anyway, it's being worked on, don't worry
femur
Mon Jun 08, 2009 4:41 pm
Files in
/file print
menu are not deleted while doing
so you can store any full or partial "persistent" configuration in such name.rsc file. I do this that way everytime.
But when you are logged into radio device by wireless link, and when you perform
you loose connection and no chance to connect again. Then drive your car, knock to the customer door, connect your laptop by ethernet wire and
/import name.rsc
to restore configuration.
So we ask Mikrotik for special rsc file making possible to
/import special-name.rsc
automagically after
You can call this "green technology", because we will save a lot of fuel and a lot of amazonian jungle that way :).
NAB
Trainer
Trainer
Mon Jun 08, 2009 5:10 pm
Files in
/file print
Yes, I understand that (the posts above make this point very clear). My question was that if you have a value stored which dictates what file should be run on reset, why (and how) won't that value itself be reset?
If (by whatever means) it isn't reset, then how does one perform a reset such that the value itself is reset?
Consider a hypothetical scenario. Let's say I give you a router. I've written a script which does:
/system console disable 0
/ip firewall filter add chain=input action=drop
/ip firewall filter add chain=forward action=drop
/ip firewall filter add chain=output action=drop
(very simple, I'd probably do more if I were being difficult!!) and I have set the value 'run-script-on-reset' to run that script.
How do you get access to the box, or is it effectively permanently bricked?
That's what I was asking.
femur
Mon Jun 08, 2009 5:47 pm
It is not our problem :). But seriously speaking... there is default configuration script working just now.
/system default-configuration print
and this default script runs after
so I imagine, that our friends from Lativia know trick to run any script after reset.
Our suggestion is simply to extend functionality allowing us writing additional default scripts or eventually a way to edit existing default script (using netinstall for setting own default script I know, but it is useless without using a car and without wasting fuel). I rather mean editing straight from menu.
It is of course possible even now. You can simply change password and forget it :).
Both reasons you can resolve by netinstall.
NAB
Trainer
Trainer
Tue Jun 09, 2009 11:29 am
Except that resetting the box will reset the password anyway.
nz_monkey
Tue Dec 22, 2009 11:04 am
For reference, this feature was added to RouterOS from 3.30 onwards.
Syntax is: /system reset-configuration run-after-reset=base_config.rsc
where base_config.rsc is the script you want to run after reboot.
telepro
Thu Aug 22, 2013 8:12 pm
Does this feature - running a .rsc file automatically after a /system reset-configuration
work in the latest 6.03 revisions?
i have placed a file in the files window (x.rsc) and executed the command:
/system reset-configuration run-after-reset=x.rsc
The configuration is executed, the router reboots, but the x.rsc file is not executed.
What am i missing?
thanks in advance
Users browsing this forum: GoogleOther [Bot] and 48 guests
