EngAMoktar
Winbox: How to connect to a MT Behind MT ?
Wed Dec 17, 2008 1:55 am
I have two Mikrotik Systems
"A" is my main one , i do connect to it remotely fine , from anywhere .
"B" is behind "A" , i cannot connect to it via winbox if not locally !
Is it possible to connect to "B" remotely via winbox from anywhere ?
Thanks ...
bellis
Re: Winbox: How to connect to a MT Behind MT ?
Wed Dec 17, 2008 2:32 am
you need to set up routes for your private ip's. then you should be able to winbox via ip addy.
Thanks ...
"If it ain't broke, you're not tryin"
EngAMoktar
Wed Dec 17, 2008 2:34 am
thanx , but can you give me more details , plz ?
janisk
Wed Dec 17, 2008 11:05 am
if one of your mt is with real ip address, and second is deeper into local area and you cannot reach it via ip address, as it does not have real ip address, make yourself a part of your local area by making a tunnel to outer router, so you get all the resources of your local network, local routes.
choose one of VPN solutions, like PPTP
forgot, you can change winbox default port on router. so make dstnat rules that will redirect you to the correct router inside your local area
Users browsing this forum: Paternot and 44 guests
