phil1995
Print system configuration
Fri Jan 09, 2009 10:08 pm
Can someone tell me how to print out the configuration of a router?
I am building up a new router that will have very similar configuration and would like to print out my current one and use it as a reference sheet.
Any help would be greatly appreciated.
roadrunner
Re: Print system configuration
Fri Jan 09, 2009 10:39 pm
Try the command 'export' you do it in a specific directory to only save those settings if needed.
You can also just use the backup & restore system.
Export outputs a text file with all the commands, I don't think backup is a text file that can be read.
You might want to only export certain parts, exporting the whole configuration may generate too large of a file to easily use.
phil1995
Fri Jan 09, 2009 10:47 pm
Thanks for you help.
ziigmund
Thu Nov 22, 2018 3:06 pm
add fast-forward=no name=bridge1
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
/interface bridge settings
set use-ip-firewall=yes
add address=10.1.1.50/24 network=10.1.1.0
/system routerboard settings
set silent-boot=no
The gateway is another mikrotik behind my bridge. I want to filter the traffic before the gateway.
Jotne
Thu Nov 22, 2018 3:35 pm
You may have posten at a wrong location. This information has nothing to do with the topic :)
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
Steveocee
Thu Nov 22, 2018 4:42 pm
Using export via terminal is the best way to "see" your config in it's raw format. A slightly more person friendly approach would be to do something like;
export file=myrouterexport
This saves the export locally.
Then using Winbox go into "Files" and download the complete RSC file.
Steve "Steveocee" Carter
PC Gamer, Airsofter, MikroTik Nerd
My Website - My MikroTik Tutorials
Users browsing this forum: Bing [Bot], verbovet and 54 guests
