mushmx
Transparent proxy in MKT V3.14 "Solved"
Tue Jan 13, 2009 1:25 am
Hi
I need a transparent proxy to my lan 192.168.1.x/24 but the next rule not working in mkt V3.14
ip firewall nat> add chain=dstnat protocol=tcp dst-port=80 action=redirect to-ports=8000
In other mikrotik v2.9.51 the last rule work fine, has changed the rule to v3.X?
Best regard.
ashish
Long time Member
Long time Member
Re: Transparent proxy in MKT V3.14
Tue Jan 13, 2009 8:37 am
Nothing wrong..try with latest Version 3.18
- AP - ASHISH PATEL - 757 309 0236 -
Chupaka
Tue Jan 13, 2009 12:31 pm
what do you mean saying 'not working'? do it count packets, or not?
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
janisk
Tue Jan 13, 2009 2:03 pm
if you set your web browser to use proxy, does it work?
mushmx
Tue Jan 13, 2009 4:41 pm
Hi
The rule not count packets and the proxy not block the website and not save any cache. So I tried with other version of MKT V3.X and the result is the same. Other thing that I did was modify the value of the Connection Limit 100/32 to 0/32 and this not helped me :(
Best regard.
mushmx
Tue Jan 13, 2009 4:56 pm
Hi
If I change the setting in my browse it work fine but I don't want do this with all clients; I need that the proxy are transparent without any modification in the client browser; like in the other version V2.9.51
Best regard. :D
Thanks for all.
Chupaka
Tue Jan 13, 2009 5:22 pm
hmmm... you don't use bridge, do you?..
mushmx
Tue Jan 13, 2009 5:30 pm
Yes I'm using a bridge (Ether1, Ether2 and WLan1). In the Ether1 is connected the cable to Modem "2wire", the Ether2 and WLAN1 are my client network.
mushmx
Tue Jan 13, 2009 9:53 pm
This is an example about I want to do. When I configured a Hotspot into MKT all work fine but if I want do without Hotspot like the picture then the proxy not work. :(
Thanks for all.
JwTPN
Tue Jan 13, 2009 10:45 pm
Dont forget in V3 you have to go to the bridge settings and tell it to use the firewall, perhaps that is why nothing appears to be passing through the firewall?
Cheers
Justin
Justin Wells
Nayland College
New Zealand
mushmx
Re: Transparent proxy in MKT V3.14 "Solved"
Tue Jan 13, 2009 11:56 pm
Cheers
Justin
Hi JwTPN
Thanks for the reply, finally the proxy are workign :D I just enabled in Bridge setting "USE IP Firewall"
Best regard
Users browsing this forum: Google [Bot], jkyawesome, McSee and 177 guests
