rpingar
Long time Member
Long time Member
*) allow to use ip firewall for encapsulated PPPoE packets;
Wed Jan 28, 2009 4:36 pm
may we recive more detailed explanation about it?
is mT able to inspect the packet inside PPPoE tunnels or it is able to just let pppoe flow inside the firewall.
regards
mrz
Re: *) allow to use ip firewall for encapsulated PPPoE packets;
Wed Jan 28, 2009 4:45 pm
It means that when this option is set ip firewall will be able to see packets encapsulated into pppoe
rpingar
Long time Member
Long time Member
Wed Jan 28, 2009 4:47 pm
so can I cut p2p traffic incapsulated into a pppoe tunnel?
regrds
Chupaka
Wed Jan 28, 2009 5:12 pm
hm... what about encrypted traffic?..
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
npero
Wed Jan 28, 2009 5:16 pm
Yes you can do anything like regular traffic passing bridge when enabled bridge ip firewall.
See my post http://forum.mikrotik.com/viewtopic.php?f=2&t=29256 very good feature but if you have before configured firewall for regular traffic have lot problem like me in 3.19 now I can disable this feature where not need and also enable where needed.
Thanks mikrotik
mrz
Thu Jan 29, 2009 10:04 am
This feature won't work with encrypted pppoe
NetworkPro
Fri Jan 30, 2009 10:53 pm
And p2p drop will not work for for the encrypted p2p connections.
But what about the tunnel? Won't it try to retransmit if a packet is dropped? Or won't it damage the tunnel somehow?
And by the way, where is this setting? Is it in CLI? What is it?
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
Users browsing this forum: MSN [Bot] and 67 guests
