mushmx
What I need to use 4.9Ghz in RouterOS???
Thu Feb 05, 2009 12:53 am
Hi
I will start a project and we must use the 4.9Ghz frecuency but I have a doubt about if I need upgrade the license Level 4 or the RouterOS will recognize the card by default.
plz, any suggestions will help me :D
Best regard.
chapex
Re: What I need to use 4.9Ghz in RouterOS???
Thu Feb 05, 2009 5:56 am
change the local regulation of the other country is illegal and unethical. Buy a Superchannel license :D
very low cost!
regards
pd: save money to spend on expensive 4.9 cards
Ubnet datacenter: bandwith transport
mushmx
Fri Feb 06, 2009 5:28 am
very low cost!
regards
Thanks for the reply, but I must use 4.9Ghz because is the license to police deparment; so I just need know if with the leve 4 of RouterOS I can will use the 4.9Ghz or I will need buy other license. Because actually in the combotext only apper 5Ghz and 2.4Ghz
Best Regard.
chapex
Fri Feb 06, 2009 6:13 pm
they are cards in 2.4 working with frequency convertors, it is because of it that often can be observed nets in this spectrum. It is necessary to look for the suitable channels, in the same way as for one xr9.
regards
roc-noc.com
Forum Veteran
Forum Veteran
Sat Feb 07, 2009 9:33 pm
very low cost!
regards
Best Regard.
I have installed these under license for our local government. You need to buy the Custom Frequency Upgrade for each RouterBoard that you are running at 4.9GHz. You can buy thius directly from Mikrotik or from Mikrotik distributors that sell them.
Tom
PS You need this upgrade even if you are using the sr4 card for 4.9GHz.
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
mushmx
Sun Feb 08, 2009 11:03 pm
very low cost!
regards
Best Regard.
Tom
Thank you Tom, this infomation is very helpful for me.
Best regard.
Users browsing this forum: Madcatua, millenium7, phongqc, samwarez and 197 guests
