gimmepatiencequickly
MT V3.20 errors
Mon Feb 23, 2009 11:45 am
Hello guys.
I installed mikrotik OS ver 3.20 on a CPE for testing purposes, and now I cannot log into the router... I tried using winbox, I tried telnet and SSH, but nothing works. The router does connect to the main AP, (Exactly as it did before the upgrade) and it is supplying the client with internet through the AP. I can FTP into it without any problems or timeouts.
I have uploaded routeros-rb500-2.9.51.npk just so that I can do a downgrade
When I try to log in using CLI client I get:
could not receive confirmation to CTRL_READY from loader
Every now and then, it shows the MIKROTIK Ascii art, but never shows the CLI prompt.
Edit: Ok, after retrying for about 10 minutes, I eventually got a prompt, and used /system package downgrade
Waiting for results.
EDIT: Ok, waited for about 10 minutes, it took a while for me to type anything, (or at least see the echo) and the router eventually rebooted, now I cannot ping it, and it also does not connect to AP.
Seems as though I will have to drive to the CPE and set it up from scratch
*sigh*
Defer not till tomorrow to be wise, tomorrow's sun to thee may never
rise.
--- William Congreve
Users browsing this forum: Majestic-12 [Bot] and 217 guests
