Equis
Forum Veteran
Forum Veteran
PPTP vrs PPPOE
Tue Mar 03, 2009 10:48 am
Hello
I have about 1000 PPTP users terminating on a 3000Mhz server and its maxing out.
It only passes about 25Mbps
I tried duel core but it was worse, apparently PPTP server only used one core.
How many peopel have you guys stuffed on a PPPOE server?
Can I expect more?
Would a rb1000 handle it better?
The documentation says 1000's of PPPOE users
savage
Re: PPTP vrs PPPOE
Tue Mar 03, 2009 10:51 am
I'd say its prob something more low level that's causing your issue... Queues, and more specfically, compression / encryption on ppptp ?
Encryption will cause a serious knock performance wise with that much traffic...
Regards,
Chris
janisk
Re: PPTP vrs PPPOE
Tue Mar 03, 2009 12:49 pm
PPPoE and PPTP use same authentication mechanisms, therefore, if you use internal DB (/ppp/secret) that is optimised for about 100 users most probably cannot handle the amount of 10 times more than that.
you should go for user-manager, even if on the same server, that will work better.
Equis
Forum Veteran
Forum Veteran
Re: PPTP vrs PPPOE
Tue Mar 03, 2009 2:00 pm
if you use internal DB (/ppp/secret) that is optimized for about 100 users most probably cannot handle the amount of 10 times more than that.
Do you think that is causing the high cpu?
If I used radius would that fix it?
I disabled encryption but that had about 10% effect.
Users browsing this forum: Google [Bot], masihbelajar and 165 guests
