wireless12
winbox login
Fri Mar 06, 2009 11:33 am
hello all.
is there any way to stop/restrict/hide specific mikrotik appearing in winbox...?
thxx
normis
Re: winbox login
Fri Mar 06, 2009 11:39 am
hide what exactly?
wireless12
Re: winbox login
Fri Mar 06, 2009 11:45 am
ok in the follwoing picture i want that mikrotik in red circle dont aapear in winbox laoder.
normis
Re: winbox login
Fri Mar 06, 2009 11:53 am
disable "ip neighbor" discovery and the "mac server"
note that in an emergency, you will not have MAC access then, only Serial Port
normis
Re: winbox login
Fri Mar 06, 2009 12:02 pm
wireless12
Re: winbox login
Fri Mar 06, 2009 12:11 pm
thxx normis
oh i c...if it is then its very dangerous to do that.. bec we hav to alter in mikrotik then and there...is there no other way to dissapear and access it in the time of need.
thxx
Chupaka
Re: winbox login
Fri Mar 06, 2009 1:44 pm
you may disable neighbour discovery only, so you will need to know MAC address for MAC Telnet/Winbox
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: Google [Bot] and 122 guests
