enk
3.22 released
Mon Mar 16, 2009 3:47 pm
RouterOS 3.22 has been released today.
What's new in 3.22:
*) added advanced switch features for RB450G;
*) added support for MetaROUTER on RB450G;
*) added support for adding physical interfaces to Metarouters;
*) added set-bgp-prepend-path action to routing filters;
*) added WinBox OSPFv3 support to routing-test package;
*) added WinBox IPv6 routes support to routing-test package;
*) console - added 'hide-sensitive' option to the export command;
*) user manager - fixed customer remove interface bug;
*) fixed Cisco BGP VPLS autodiscovery in mpls-test package;
*) fixed LDP to not disconnect on unknown capabilities of remote
peer (should help establish LDP session with Junos);
*) fixed ethernet port name reordering on RB493;
*) bonding mode balance-alb now works on RB1xx, RB4xx, RB616, RB600, RB750,
RB1000;
*) added '/interface ethernet print stats' command for RB450G and RB750;
*) fixed CSPF in routing-test to properly interpret link bandwidth;
*) added support for C-motech CNU-680 CDMA 1x EV-DO 450Mhz USB Modem;
What's new in 3.21:
*) backported MetaROUTER support for RB4xx from v4;
*) added WinBox MPLS & VPLS support mpls-test package;
*) added WinBox BGP support to routing-test package;
*) api - added query support for 'print' command;
*) added support for bsd-syslog;
*) added TFTP server;
*) added authorization and TLS support to email tool;
*) added pppoe-scanner;
*) added tftp protocol support to fetch tool;
*) fixed ipsec policy priority to work as documented;
*) fixed BGP route selection in routing package;
*) allow to use IPsec aggressive mode with pre-shared keys;
*) fixed some problems in mesh protocol;
*) fixed https proxying with parent proxy;
*) fixed Prism shared IRQ issue;
*) fixed multiple MPLS/VPLS bugs in mpls-test;
*) fixed boot problems on some RB1000s;
*) added /interface mesh traceroute command;
*) fixed web proxy source address selection;
*) fixed pcq queue - pcq sometimes could get through more traffic
than specified in max-limit;
normis
Re: 3.22 released
Mon Mar 16, 2009 4:00 pm
finally some changes, huh ;)
mietus
Re: 3.22 released
Mon Mar 16, 2009 4:08 pm
i think i've oversleeped 3.21 and one time 3.22 this is the second ;p
normis
Re: 3.22 released
Mon Mar 16, 2009 4:14 pm
both 3.21 and 3.22 are released together, you didn't oversleep. mikrotik skipped a version this time
omega-00
Re: 3.22 released
Mon Mar 16, 2009 4:19 pm
Edit: I'm misreading and failing \/-- see below.
normis
Re: 3.22 released
Mon Mar 16, 2009 4:22 pm
Yeah what was with that? I never saw the email for 3.21 either :-|
Ozelo
Re: 3.22 released
Mon Mar 16, 2009 4:26 pm
Amazing!, Thanks a lot!
What it do? Intriguing...
Now thats a surprise! :) Thank you.
Ozelo
dingsingo
Re: 3.22 released
Mon Mar 16, 2009 4:36 pm
in 3.21 is *) added WinBox MPLS & VPLS support mpls-test package.
But i didn't see in Winbox with Version 3.22. It's again out in 3.22 ?
dingsingo
proggams2
Re: 3.22 released
Mon Mar 16, 2009 5:29 pm
pppoe-scanner? what does it do and where could we find it ?
ayufan
Re: 3.22 released
Mon Mar 16, 2009 5:58 pm
/ interface pppoe-scanner
it searches for active pppoe-servers
i personally think better would be something like dhcp alert :) maybe pppoe alert? :D
sioannou
Re: 3.22 released
Mon Mar 16, 2009 6:27 pm
When you add the packages for 3.22 to Dude so you can do a remote upgrade the version 3.22 doesn't uppear under the Upgrade submenu. Any ideas ?????
honzam
Re: 3.22 released
Mon Mar 16, 2009 6:56 pm
Where is changelog for new BIOS 2.20? http://www.routerboard.com/files/rb-2.20/CHANGELOG
Krle
Re: 3.22 released
Mon Mar 16, 2009 6:59 pm
what exactly does it do? will it mess up my configuration if i upgrade (e.g. what happens with the reordering)?
dprus
Re: 3.22 released
Mon Mar 16, 2009 7:06 pm
I was just wondering if those changes to the 450G mean that ports 2-5 can be used like a hardware switch now? I purchased one of these last week and was disappointed to find that this functionality was not supported even though it is supported in the 450 (non-G).
proggams2
Re: 3.22 released
Mon Mar 16, 2009 10:19 pm
the new usermanager mikrotik was talking about with new features because it was said it will be included, is it included in this 3.22 ??
artizzz
Re: 3.22 released
Tue Mar 17, 2009 1:33 am
dprus: can't you use any MT router as a switch ? simply make a bridge between the port witch you want to use as switch and done.
Got problems installing ROS-3.22 from an .iso - when it goes to creating partitions and formating them - kernel panics. Tryed it on various hardware (x86 like hw). Tryed out ROS-3.20 .iso - this one worked without problems.
omega-00
Re: 3.22 released
Tue Mar 17, 2009 1:46 am
I can second this - see the thread I created about it - http://forum.mikrotik.com/viewtopic.php?f=8&t=30362
ayufan
Re: 3.22 released
Tue Mar 17, 2009 2:27 am
.npk files look a little different, most probably because of small changes to package format, that's why you can't access them through dude :)
normis
Re: 3.22 released
Tue Mar 17, 2009 8:55 am
no
the opposite! it will fix the messup, if there is any
I don't understand your post. Upgrade and see.
Chupaka
Re: 3.22 released
Tue Mar 17, 2009 2:36 pm
NetInstall over Demo and No License on VMware works, but fresh install freezes on 'Harddrive found', 100% CPU load, flashing with Caps Lock and Scroll Lock...
cmartin
Re: 3.22 released
Tue Mar 17, 2009 3:37 pm
What the RB616 is? I would like to see at least short description ...
ste
Re: 3.22 released
Tue Mar 17, 2009 3:46 pm
Early announcements are problematic. Noone buys the existing stuff cause you dont want to buy old things
and noone buys the new stuff cause it's not yet available. So what do you expect from MT? :shock:
Stefan
honzam
Re: 3.22 released
Tue Mar 17, 2009 4:19 pm
What is the change in mipsbe?
normis
Re: 3.22 released
Tue Mar 17, 2009 4:22 pm
What's new in 2.20:
*) added support for RB450G;
magic
Re: 3.22 released
Tue Mar 17, 2009 4:33 pm
I don't understand your post. Upgrade and see.[/quote]
I think he didn't find the mpls menu in winbox. I didn't find it either.
honzam
Re: 3.22 released
Tue Mar 17, 2009 4:41 pm
What's new in 2.20:
csickles
Re: 3.22 released
Wed Mar 18, 2009 5:27 pm
Anyone gotten the SMTP auth to work against an Exchange 2003 server ??
Keep getting "AUTH method not supported"... :o :?
Also... the password is NOT hidden in winbox. (when the hide passwords box IS chacked).. :oops:
changeip
Re: 3.22 released
Wed Mar 18, 2009 6:32 pm
are you allowing BASIC auth with exchange, or just digest ?
chapex
Re: 3.22 released
Wed Mar 18, 2009 6:47 pm
someone eperimented error in web-proxy with sd store : "nfs file handle ...."? (on this version)
regards
csickles
Re: 3.22 released
Thu Mar 19, 2009 3:19 am
Will look at it in the AM...
THX..
roc-noc.com
Forum Veteran
Forum Veteran
Re: 3.22 released
Thu Mar 19, 2009 6:20 am
Yes, I tested this with a RB450G and it is fixed. Any of the ports 1-5 can be assigned to a master port. The master port can be any port 2-5. Port 1 cannot be a master.
Tom
roc-noc.com
Forum Veteran
Forum Veteran
Re: 3.22 released
Thu Mar 19, 2009 6:24 am
What's new in 3.22:
--cut--
--cut--
This is a feature that I have been asking for. Will be really nice when it works. Right now it just prints out a list of register names and all values are 0 and stay at 0.
Tom
msundman
Re: 3.22 released
Thu Mar 19, 2009 10:42 am
Great! Could we hope to see this on RB1000 as well any time soon?
frogale
Re: 3.22 released
Thu Mar 19, 2009 12:44 pm
There is OSPFv3 bug in v3.22.. When simple or tree queue added, OSPFv3 shutdowns..
Log snapshot when disabling simple queue rule:
simple queue changed by dude
OSPFv3 neighbor 10.38.0.1: state change from Full to Down
OSPFv3 neighbor 10.38.0.2: state change from Full to Down
OSPFv3 neighbor 10.38.0.3: state change from Full to Down
Ozelo
Re: 3.22 released
Thu Mar 19, 2009 8:09 pm
Guess this is just some missing undefined variables... ;)
Aug
Re: 3.22 released
Thu Mar 19, 2009 10:48 pm
It's not just in Dude.
In winbox you get the same results.
Auto-upgrade does not recognize the 3.22 packages. Tested with routeros-mipsbe-3.22.npk and routeros-x86-3.22.npk.
If I put the 3.22 file on the server and refresh auto-upgrade it comes back blank.
If I put the 3.20 file on the server and refresh auto-upgrade it comes back as installed.
andreacoppini
Trainer
Trainer
Re: 3.22 released
Fri Mar 20, 2009 12:56 am
I thought I was just imagining, but now that you're mentioning it....
I wanted to do a Netinstall with 3.22 earlier today. The 3.22 packages didn't show up in the list to choose the packages, while all other versions 3.20, 3.19, appeared.
gotix
Re: 3.22 released
Fri Mar 20, 2009 3:59 am
With version 3.20 i have a strange problem.....
RB433AH with 3 wireless interfaces R52H. I use to provide service at 2.4
I configured routerboard and it works, clients authenticate them self's over PPPoE.
But now all the clients that connect using wpa are unstable.
ON RB433AH with 3.20 they connect, disconnect... Any idea or experience???
I upgrade RB with OS3.22 and I hope that this problem will disappear. Any suggestion will be helpful.
Thank You
magic
Re: 3.22 released
Fri Mar 20, 2009 9:47 am
I found the same with the auto-upgrade. The upgrade works fine when I uploaded the packages with ftp to the routers. But no 3.22 packages in the auto-upgrade list.
normis
Re: 3.22 released
Fri Mar 20, 2009 9:51 am
You have to download the new Netinstall to use new packages.
The Dude will also be updated.
"/system upgrade" will be fixed in next release.
andreacoppini
Trainer
Trainer
Re: 3.22 released
Fri Mar 20, 2009 10:26 am
True, that fixed it... Tks
sioannou
Re: 3.22 released
Fri Mar 20, 2009 12:45 pm
Also to mention that the MD5 issues with BGP on 3.22 looks like they have been fixed.
Any idea when the new dude is coming out????
h4ckxy
Re: 3.22 released
Tue Mar 24, 2009 4:43 am
how i can use Multi Link PPP in v. 3.22
i got 3 pppoe client want to make them into 1 pppoe so i can benefit from the traffic and enlarge
thanks
mrz
Re: 3.22 released
Tue Mar 24, 2009 8:45 am
In pppoe client's configuration specify all three interfaces. But it will not work if your provider doesn't have this feature.
Users browsing this forum: ejaka2s, Google [Bot], GoogleOther [Bot] and 202 guests
