rxrxrx
hotspot kills my LAN
Tue Mar 17, 2009 3:31 pm
hi, im using mikrotik 3.20 to create a hotspot point.
it worked OK for a couple of weeks,then i got a call from a LAN user (no wifi ,not connected to hotspot box) that, he got a message on his browser, that asks him a username/password. which is hotspot login page.
i guess,a user has a bridge between his wireless and LAN adapter that is probaby windows' sharing internet feature or something like that.
and since mikrotik hotspot is likely doing some arp poisoning (not sure,but i guess that also), the LAN users are spoofed immediately i turn on the mikrotik box. (i had to shut down it on the first call)
how can i fix that ?
thanks
Chupaka
Re: hotspot kills my LAN
Tue Mar 17, 2009 4:38 pm
fix what? it's designed behaviour - users access hotspot independently of their network settings
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Wed Mar 18, 2009 9:13 am
if that user accidently connected to your wireless hotspot network, and got the login screen - that is what's supposed to happen. tell him not to connect to other unknown netoworks, and turn off the wifi card when not using it.
rxrxrx
Wed Mar 18, 2009 11:12 am
thanks for replies.
no the user is not accidently connected to hotspot.
and it is of course expected, for wifi users to get login pages.
|INTERNET|____|HOTSPOT|~~~~|hotspot user|_______{LAN}_______|LAN GATEWAY|______|INTERNET|
the problem is, LAN users are getting hotspot login page (not connected to hotspot directly)
Chupaka
Wed Mar 18, 2009 1:14 pm
if that user uses bridge - then LAN users ARE connected to hotspot directly, using bridge =)
rxrxrx
Wed Mar 18, 2009 2:08 pm
yeah,cant i deny that ? (that is what i mean _to_fix_ in first post.)
normis
Wed Mar 18, 2009 2:09 pm
how can you deny your client's to use bridge? they can use whatever software they want, can't they? this is like running another DHCP server in the network - it will also cause major problems.
rxrxrx
Wed Mar 18, 2009 2:24 pm
so 1 solution left for me.
disable hotspot,and use a basic dhcp server, and mac filtering (instead of giving user/pass to users) via firewall.
normis
Wed Mar 18, 2009 2:41 pm
do you think this can happen very often when somebody bridges their cards accidently? I've never heard such issues before
Chupaka
Wed Mar 18, 2009 11:36 pm
if someone from LAN complains, tell him that the reason is that user with bridge - it's not your trouble! why the hell should you answer the malicious actions of other users?
rxrxrx
Thu Mar 19, 2009 9:28 am
i am not sure of the bridge, but imho, its the only possibility.
i cant control users to not to make bridges etc. that is right.
but the box that is doing arp spoofing is mine,anyways.
Chupaka
Thu Mar 19, 2009 12:04 pm
if somebody has stolen your car and knocked down somebody - it's not your problem again =)
wireless12
Thu Mar 19, 2009 12:17 pm
ooooooooops if its really an ARP poisoning (i wish is is not) only GOD can save you. if suffer a lot by this issue and my entire wisp network become a fish market. but i don't know how i came out with it, i remember i disallow all the wlan interface and allow them one by one only after formating the computer and installing a decent anti-virus in each computer.
then only i was able to was able to make my network stable agian
hope this helps
rxrxrx
Thu Mar 19, 2009 12:20 pm
hope this helps
arp spoofing box is not an infected workstation, it is the design of hotspot.
Users browsing this forum: MSN [Bot] and 81 guests
