tashielb
Posting Message on Winbox Login
Wed Mar 25, 2009 9:57 am
Hi all
I Work in an evironment with multiple technicians who all have different levels of skills, i recently setup a mikrotik to do some policy routing and bandwidth monitoring and ip blocking ETC. ie, it is a bit more complicated than our usual setup. the problem is, everytime a different technician goes out to this client, they mess with my mik rules.
I want to know if and how i can post a message the instant someone logs on to a mikrotik using winbox, to say something arb like "please do not fiddle with these settings etc"
Thanks in advance.
normis
Re: Posting Message on Winbox Login
Wed Mar 25, 2009 10:01 am
Either add comments to your rules, so show others what they do (and to remind yourself), or use the Note to show at every login:
[admin@Ms_GW] > system note
[admin@Ms_GW] /system note> print
  show-at-login: yes
           note: ""
tashielb
Wed Mar 25, 2009 12:10 pm
Sorry Normis
I dont understand the "note" switch you are talking about?
I am a bit of a novice i suppose.
Could you possible explain further?
thanks for the quick reply.
normis
Wed Mar 25, 2009 12:15 pm
enter something in the "note" menu, and that text will always show up when somebody logs in
normis
You can even add bigger and more complicated notes, with line breaks
tashielb
Wed Mar 25, 2009 12:32 pm
Thanks Normis, Its helps alot.
Is it possible to put vb scripts on a mikrotik?
Im thinking of putting one in so the moment anyone logs on, a box pops up with the message.
normis
Wed Mar 25, 2009 12:39 pm
pops up from where? nope, you can't do that. you can use "system script" to make RouterOS scripts, but no VB
tashielb
Wed Mar 25, 2009 12:41 pm
When the user logins to winbox, popup box presents itself, with my message.
normis
Wed Mar 25, 2009 1:04 pm
nope, winbox can't interfere with your windows system, it's not a virus ;)
tashielb
Thu Mar 26, 2009 11:16 am
Haha yeah point taken :)
Sorry to pry. Thanks for the help.
sanjeev
Thu Mar 26, 2009 2:34 pm
please inform all of the user to click on "New Terminal" to see the message.
or will the terminal pop up itself.
normis
Thu Mar 26, 2009 2:35 pm
true, Winbox doesn't support these notes. You can deny access to winbox, and allow only SSH. let them learn command line :)
gtb
Thu Mar 26, 2020 3:58 am
So, out of the box when I Winbox to brand new Mikrotik Router I get a popup window with a page of text explaining its configuration - HOW CAN I EDIT THAT POPUP WINDOW?
sleerf
Fri Oct 30, 2020 8:12 pm
Users browsing this forum: hackerduni and 152 guests
