surfnet
lowest dBm for nstreme
Tue May 10, 2005 6:25 pm
I have read alot of posts about the lowest Nstreme signal. alot of people say that -65 is the lowest.. That confuses me, I have 2 nstreme connections . 1 at -75 and the other at -69. I get 20megs of download on a 24mb connection rate.. So How come mine works if it isnt that low..
markon
Signal Level
Thu May 12, 2005 2:06 am
:o The signal level of the client and base are not directly the cause of NSTREME trouble. You need to check the dBm senistivity of the receieve section of the radio card.
For example, if a radio card requires -71db to operate at 24mbits level, then a signal of -72 will not work well and the radio cards interal rate will drop down untill it has reached a Speed level which falls into the dBm senistivity range.
Many, of the Atheros based OEM cards out there have some manufacturing problems. The CISPA LAB tested 100 CM-9 board from one manufacture and found that the stated -71db level was different on each board. Some were better then stated in their documents, however, over 70% were worse then stated in their documents.
The bottom line is this, YOU MUST UNDERSTAND RF! Knowledge of IP and no knowledge of RF means you will never get out of the MK system what you think you should.
NEVER EXPECT SOFTWARE TO MAKEUP FOR BAD HARDWARE!
surfnet
Thu May 12, 2005 2:22 am
so I guess I am doing great if I have a -75dBm signal with nstreme and a 20 meg throughput? :lol:
tully
Thu May 12, 2005 12:47 pm
The Nstreme in v2.9rcX now has a dynamic feature which removes the 'high ping' sometimes that could be seen in a link that had allot losses. Also, the rc2 has an improvement for systems where the CPU was the bottleneck. I suggest trying with the newer version.
John
rickard
-80 dBm woking well with Nstream on.
Wed May 18, 2005 11:23 pm
I have a lot of customers running with signal -77 dBm with Nstream and they get up to 19 Mbit Real TCP this is with 2.9 RC2
and the client is 2.8.26 on 2.4 Ghz G-only
Users browsing this forum: massinia, Resident007 and 76 guests
