chojrak11
Winbox suggestion
Sun Apr 05, 2009 10:43 am
I have DOZENS of sessions saved in Winbox. That really saves me from remembering DOZENS of IPs, usernames and passwords.
Would it be possible to have some sort of "find" textbox, similar to what is in almost every window of RouterOS, that would filter displayed sessions to those containing typed text?
Thank you in advance.
Keep up the good work!
normis
Re: Winbox suggestion
Mon Apr 06, 2009 9:38 am
Why not use The Dude, which was made for this purpose?
chojrak11
Tue Apr 07, 2009 8:47 am
Thanks Normis for the suggestion, however I forgot to mention that the sessions are from DOZENS different customers... So they are not connected with each other and certainly won't fit on one map :-)
Winbox is a great tool that manages alll of them with ease and allows me to log in to each one in just seconds. I'll try Dude but I suspect that it gives too much overhead in my scenario.
And please think about the "find" textbox, IMO it shouldn't be a big deal for you.
Thanks!
normis
Tue Apr 07, 2009 8:49 am
The Dude doesn't need to have all devices in one map, connected all together. You can just add random devices with no real relation, just make a list like you have in winbox. They don't even need to be monitored, you can use Dude for simple management.
chojrak11
Tue Apr 07, 2009 10:08 am
Thanks for the suggestion, I'll give it a try and report back my results. Thanks very much!
normis
Tue Apr 07, 2009 10:11 am
Example list of devices in Dude:
cmon69
Tue Apr 07, 2009 5:16 pm
It sure would be nice to have folders in winbox so a person could store customers in one folder and towers in another! It would make it so much quicker than having to scroll down a very long list! If there were folders one could sort clients by their respective subnets.
Christapher James Hasher
Waseca Wireless
Don't blame me, I didn't drink the cool-aide!
normis
Wed Apr 08, 2009 9:19 am
is the above not the same thing?
chojrak11
Wed Apr 08, 2009 12:05 pm
Normis, The Dude solution is definitely not as good as find/filter button in Winbox would be... In order to use Dude you need to run local server (because it must work even if the whole network is down). Another issue is that in Dude there is no session manager - so you cannot save credentials for different Dude servers, you have to enter them by hand whenever you want to connect to other Dude server.
Thus I'm still lobbying for a simple find/filter button in Winbox that would display only those sessions that contains entered substring in name, IP, MAC address, or username.
Think also this way: the number of sessions in Winbox for any given Winbox user will not shrink. So the issue will pop up again sooner or later. And the solution is programmaticaly very simple.
You are specialized in useful tools so I really hope you will do it :-)
Thanks in advance.
normis
Wed Apr 08, 2009 12:12 pm
I don't think we will expand the winbox loader anymore, you must use the Dude. This is why I ask, what improvements to the Dude do you want to see, to make it usable in such way?
chojrak11
Wed Apr 08, 2009 1:49 pm
Definitely one thing. After clicking the "thunder" icon on top left, there should be list of Dude Servers to choose from, and an ability to save credentials:
Session Name, IP, Username, Password
The list could look much like it looks in Winbox.
This would make much easier switching from a local server to other servers, and managing these accounts.
And of course I opt for plain text passwords in the .cfg file, like :-)
If it seems unclear to you, just let me know.
But I'll still lobby for the Winbox solution, it seems to be an hour or two for an average developer ;-)
Thanks very much.
normis
Wed Apr 08, 2009 2:41 pm
You can do all that.
- connect to local server
- go to global "settings"
- add all the AGENTS that you need (all remote dude servers that you use)
- make a new map
- click on "discover" and select the agent to use
this way, all your agent maps will be inside ONE dude instance
chojrak11
Wed Apr 08, 2009 5:22 pm
I'm missing the option to move devices between maps. After adding e.g. 30 devices to one map, I realized that ONLY option to organize and filter them out would be the "Map" dropdown. But after adding I'm unable to move them to other map, so I suppose I'll have to drop them and recreate again... Or is there any faster method?
Chupaka
Thu Apr 09, 2009 12:04 am
I'd prefer encryption of C:\Documents and Settings\%USER%\Application Data\Mikrotik\Winbox\winbox.cfg with all saved plaintext passwords first...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Thu Apr 09, 2009 8:55 am
copy and paste works for moving
cmon69
Fri Apr 10, 2009 7:34 am
I don’t use Dude because it causes some of my older CPE's to become non-responsive. And I don’t have the time to try and figure out why on my own.
By the time I get the help I need by asking on this forum many of my customers will be pissed off enough to no longer subscribe to my service!
I sure Dude is probably a great program, but I have had nothing but problems with my network when ever I have tried to use it.
Having it always running in the background is a pain.
I like Winbox!!!!!!!!!!!!!!!!!!!!
Waseca Wireless
Chupaka
Fri Apr 10, 2009 11:13 am
so don't run it in background. run it only when you need it
cmon69
Tue Apr 14, 2009 6:41 am
I got a better Idea! ...... I just wont install it!!!!
Waseca Wireless
Aug
Tue Apr 14, 2009 7:23 am
In dude you can add all the devices without polling them.
I know what you mean causing problems with older devices.
Add the devices manually and you'll have your list of devices.
Aug
cmon69
Tue Apr 14, 2009 8:00 am
Aug
Thanks for the advice
I'll give it a try!
Waseca Wireless
Paxy
Thu Apr 16, 2009 10:52 am
winbox.cfg saves plain text passwords !
Why does not it save MD5 or SHA1 password, and not to use plan text authentification when sending password (even with secure connection).
Just simply store and authentificate with MD5 or SHA1 hashed password, like many others programs.
chojrak11
Thu Apr 16, 2009 11:04 am
IMO this is a feature not a problem. It's useful when there's a need to recall a password.
I don't let anyone touch my laptop, and it is BitLocker'd so I DON'T REALLY CARE about this. And so should you.
NAB
Trainer
Trainer
Thu Apr 16, 2009 1:27 pm
winbox.exe takes three optional parameters/arguments:
winbox [location [username [password]]]
e.g.
winbox firewall.business.com admin mysecret
So you could get around both of the problems mentioned here (security - lack of encryption of winbox.cfg file and structure - folders per site/user/whatever) by writing your own wrapper for Winbox which stores passwords securely and allows you to organise the data howsoever you wish.
Alternatively, you could just create a whole load of Windows shortcuts organised however you like and (optionally) stored in an encrypted filesystem.
Or you could use something like http://keepass.info/ as your wrapper and have it automatically launch Winbox with the correct parameters.
Just my 2p.
Nick.
Chupaka
Thu Apr 16, 2009 1:41 pm
isn't it possible to obtain command line parameters of any user's process in system? =)
ayufan
Thu Apr 16, 2009 2:34 pm
It would be nice if winbox could register protocol like that:
winbox://login:password@address
or at least parse
winbox winbox://login:password@address
hAP AC, TP-Link Archer C7 v2, RB951G, RB450G, RPI2, RPI zero
normis
Thu Apr 16, 2009 2:37 pm
or at least parse
hmm but what is this then?
winbox.exe 10.1.10.1 admin mysecret
NAB
Trainer
Trainer
Thu Apr 16, 2009 3:25 pm
Yup. I was hoping that Winbox would do something sensible in this regard (spawn child, kill parent?), but I haven't tested it and I suspect that my optimism is unplaced!
Nick.
Chupaka
Thu Apr 16, 2009 4:13 pm
or at least parse
well, the second is command-line. the first is URL Handler. from the webbrowser you can only run URL =)
normis
Thu Apr 16, 2009 4:14 pm
I know, but what did he mean by "parse". what do you need URL handlers for, is there a lot of situations where you want to call winbox from within a webpage? not to mention storing password in that webpage in plain sight :)
Chupaka
Thu Apr 16, 2009 4:27 pm
it simply means cutting of 'winbox://' from command line and replacing of %20 with space, so one can use winbox://address%20user%20password URL to run WinBox =)
p.s. https is not so plain, and browser's cache is not less secure than winbox.cfg with plaintext passwords =)
janisk
Thu Apr 16, 2009 4:35 pm
sorry, but all this looks like reinventing the wheel:
at first:
Q:we need something better than winbox
A:use DUDE
then:
Q: we do not want to use DUDE, because it is "pinging" around
A: turn that off
Q: what else i can use, i do not want to use DUDE, you should improve winbox
A: DUDE is feature rich tool that can replace winbox.
if you look at dude as a winbox replacement - you can simply add devices, turn all probes down, assign routers in groups, manage upgrades of those groups etc. It is feature rich power-tool.
IMHO winbox is screwdriver while DUDE is kitted out robotic arm.
Chupaka
Thu Apr 16, 2009 4:39 pm
yesss, I like to go shopping on my 'M1 brams' tank =)
janisk
Thu Apr 16, 2009 4:43 pm
point is - no one is going to improve "screwdriver" while you can strip your "tank" to bare minimum if features you need and do what you want to do. After some time, you will notice, that you are using more and more features of The DUDE and it will seem impossible - how you did without it.
It is really easy to use and really addictive :) configuring several routers at time - a breathe.
NAB
Trainer
Trainer
Thu Apr 16, 2009 5:30 pm
That path leads to bloat. Sometimes it is better/easier/faster to have the screwdriver.
Correct me if I'm wrong, but doesn't The Dude just start up winbox for you anyway? If so, then what you're proposing is an additional layer which seems somewhat redundant to me.
Also, and again correct me if I'm wrong, don't I have to install The Dude? Winbox runs as a standalone executable which means I can run it on any machine anywhere without any hassle.
Nick.
ayufan
Thu Apr 16, 2009 5:43 pm
okey I'll do that by myself ;p
chojrak11
Fri Apr 17, 2009 11:03 am
Janisk I appreciate your opinion, however the whole thing started with a tiny feature request for a "find" textbox in Winbox ;-) That simple thing would ease management of even thousands of sessions... If I would be able to just filter them by name or IP, I wouldn't in most cases need DUDE. I like DUDE and I use it in some places, where history and alerts matter, but for everyday use, to just login and manage routers I prefer Winbox for now...
I can bet that many of us, your users, share my opinion ;-)
Have a nice day.
chojrak11
Fri Apr 17, 2009 11:08 am
Nick.
No, wait! Do you use Winbox on server where dozens of potential attackers are logged at the same time and do nothing but sniff command line parameters??? No, you use it exclusively on your PC where no-one can log on, and if she can, she is unable to do what you described. Why you need such excess security measures? Aren't you able to just secure yourself?...
Chupaka
Fri Apr 17, 2009 11:35 am
chojrak11, in that case plaintext passwords in text file are not prolem too =)
chojrak11
Fri Apr 17, 2009 3:26 pm
I never said it is a problem, TrueCrypt / BitLocker helps to not care about such details ;-)
Chupaka
Fri Apr 17, 2009 6:01 pm
will they help to allow WinBox to acces his config and block other programs from accessing it?
chojrak11
Fri Apr 17, 2009 8:41 pm
This is going OT, but I want to answer. Do you install random crap on your production laptop? Do you browse random and/or questionable sites on that machine? Do you allow random people to use your laptop? I don't, so I don't care that all programs can read my winbox.cfg. Besides, there are far more precious things than winbox.cfg that needs to be protected. I care about that and I'm also making regular backups. With TrueCrypt -- if they steal my laptop, I win. They have only a replaceable brick worth nothing more than a few bucks.
Back to topic, if Mikrotik people won't decide to implement "find" textbox, I'm probably gonna make the wrapper as was suggested to call the Winbox executable with parameters. Mikrotik people -- if you're still following -- could you post the format of winbox.cfg so a custom application can reliably read it? This is not a secret I suppose ;-) Thanks in advance.
ayufan
Sat Apr 18, 2009 2:17 am
[CUT]
adm1329
Sat Apr 18, 2009 2:43 am
Not true, there are electric screwdrivers, different bits, different sizes, and different shapes and there are still improvements occasionally being made. I don't lug around my desktop to check my e-mail everywhere I go, I use my blackberry, but I don't use it to just sit around and surf the web when I can use my desktop or laptop instead.
I personally prefer winbox for my everyday use.
chojrak11
Sat Apr 18, 2009 10:43 am
If you are still interested look at my blog :)
Wow THAT is really fast. Thank you very much!
Users browsing this forum: Extrems and 162 guests
