a4ubd
transparent proxy for public ip
Tue Apr 07, 2009 6:10 pm
Hi forum,
Is it possible to make transparent proxy in Public IP network ? I mean the client network is getting public ip, How to redirect client http port to proxy server where their is no NAT running ?
Regards
"a4ubd"
Chupaka
Re: transparent proxy for public ip
Wed Apr 08, 2009 11:41 pm
if you need to preserve users' IPs - then you should use external Squid proxy with Balabit TProxy feature enabled. on ROS you may only redirect to internal proxy, so websites will see router's IP, not user's one
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
a4ubd
Sat Apr 11, 2009 1:14 pm
How do Mikrotik user can use that external proxy?
Chupaka
Mon Apr 13, 2009 8:43 am
just setup Squid box between MikroTik and Internet
dormador
Mon Apr 13, 2009 8:10 pm
when i do that i can enter mikrotik os inside my network not els
so i cant enter my usermanger from explorer abroud my network
we need another way
Chupaka
Mon Apr 13, 2009 9:02 pm
sorry, I don't understand you
if you do not need some kind of access - block it! there's none of Squid's business
dannyboy
Thu May 07, 2009 5:15 am
Hello, how do you tell mikrotik to look at transparrent proxy ?
Ok, I want to setup squid box, from what I understand we put the squid box after MT and Internet connection. So I will have the squid box setup internaly... I have no problem with that, now how do I tell MT to send requests to that squid box? I am using hotspot on my MT.... Can you explain the configuration, I am not familiar with the setup web proxy.
Daniel
Chupaka
Thu May 07, 2009 1:35 pm
you should either setup dst-NAT of 80 port to your Squid, or setup NAT redirect of port 80 to ROS Proxy and set Parent Proxy to your Squid in you ROS Proxy
a4ubd
Wed Jun 03, 2009 12:50 pm
Is it possible to do dst_NAT in public ip ?
Chupaka
Wed Jun 03, 2009 9:37 pm
yes, why not. just do not forget to masquerade that traffic for clients with internal addresses
Users browsing this forum: Baidu [Spider], spr41178 and 74 guests
