canram
2.9 RC1 - WPA-PSK
Thu May 12, 2005 12:44 am
Does anyone succeed in getting WPA-PSK work with 2.9 RC1?
I tried several Clients.
- Windows XP SP1
- Windows XP SP2
- Linksys Wrt54G running openWrt
Every Client is trying to connect to the WPA-Running MikrotikOS-Machine but does not get any connection. MikrotikOS-Logfile shows permanent connects and disconnects from my clients.
tneumann
Re: 2.9 RC1 - WPA-PSK
Fri May 13, 2005 12:42 am
Yes.
I am using WPA-PSK/TKIP succesfully with Windows XP, though I am
not using Windows' own WPA support but instead
Intel ProSet Wireless (on Centrino Notebooks with integrated Intel-based WLAN cards)
or the Odyssey Client from Funk Software on notebooks with Orinocco PCMCIA cards.
Are you trying to use TKIP or AES encryption?
--Tom
canram
Fri May 13, 2005 6:59 am
I tried it several times with TKIP and several times with AES. But I did not try it with an commercial Client like Odyssey Client. Is it possible for you, to test WPA with the Windows-XP Built-In Client?
I´ll try RC2 amd Odyssey this evening on my XP-Boxes and WPA-Supplicant on my OpenWRT-Box.
I´ll report my results ASAP.
canram
Sat May 14, 2005 12:09 pm
Yesterday, I tried following:
- WPA-PSK between 2.9 RC2 and OpenWRT+WPA-Supplicant
- WPA-PSK between 2.9 RC2 and Odysse-WPA on Windows XP.
Both worked fine with TKIP and with AES.
Yet, integrated WPA-Client of Windows XP does not work with 2.9 RC2. But this does not really matter :)
stephenpatrick
Forum Veteran
Forum Veteran
Sat May 14, 2005 12:46 pm
"does not matter" ...... ? :(
What if people want to use it ?
Would be nice to see this fixed, many people use in-built WinXP features. :)
CableFree - Wireless Excellence - Microwave, E-band Radios, Free Space Optics, High performance Radios & Routers
http://www.cablefree.net
tneumann
Wed Aug 03, 2005 10:59 pm
Just to revive an old topic, here's an update on WPA-PSK. It turned out that despite
my former statement that I got a working WPA-PSK/TKIP connection, I was wrong.
After some more intesive testing I found out that it almost always worked for a few minutes,
but then major dropouts and disconnects came up and the client would not manage to
reassociate to the AP.
This became even more visible with the new wireless-test package for 2.9rc7.
With the new package the WPA connection did not even start to come up successfully.
I took that as an opportunity to revisit this issue and I am happy let you know that
MT support confirmed and fixed a WPA bug. I now received a special version of
the 2.9rc7 wireless-test package that finally is stable with WPA-PSK, so the fix will
hopefully soon be available in the next mainline releases.
--Tom
sten
Forum Veteran
Forum Veteran
Wed Aug 03, 2005 11:21 pm
Oooh, i am using this feature (TKIP with Intel PROset) with my home gateway. Could you share a copy of that wireless package? Does anyone know the release date for a new RC version?
Sure hope they get UPnP fixed this time.
tneumann
Thu Aug 04, 2005 2:13 pm
Sure, email me at tn.expires.20050830(at)gosingen.net and I'll send you the package.
--Tom
Users browsing this forum: klaus007, Mett, samwarez, Zacharias and 208 guests
