changeip
SNMP OID for Script Results
Thu Apr 09, 2009 9:02 am
This is directed at Mikrotik - I know tons of users would benefit.
Can you please extend SNMP to allow results of scripts to be returned, ie:
/system script print oid
0.1.2.3.4.5.6.7.8.9.0.1 script1
0.1.2.3.4.5.6.7.8.9.0.2 script2
then you could perform snmp get against the OID to run the script and return the result to the snmp get request. Pretttttttyyyy please.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
changeip
Re: SNMP OID for Script Results
Thu Apr 09, 2009 9:06 am
or just allow variables to have OIDs:
[@cip-office] > :env print
"temp"="running"
and
[@cip-office] > :env print oid
"temp"="running" 0.1.2.3.4.5.6.7.8.9.0.1
then you could query just about anything you could dream of by setting the variable in a script.
normis
Thu Apr 09, 2009 9:08 am
why do you need this? example?
did you know that the Dude can get results of any command even if there is no OID for it?
Chupaka
Thu Apr 09, 2009 9:47 am
get var by The Dude, then run external program and send the value to it - it's so romantic =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
normis
Thu Apr 09, 2009 9:58 am
it depends on where you need that var. if it's in dude, you don't need to send it anywhere. if not in dude, then of course nothing I can do :)
Chupaka
Thu Apr 09, 2009 10:10 am
not now, but in future releases =)
BrianHiggins
Long time Member
Long time Member
Fri Apr 17, 2009 12:05 am
I second this request... this is something that I've asked for for a long time (I think I even listed it on my requests when i started the original v4.0 Feature Requests thread...)
-Brian
http://www.aditumims.com
Complete web based ISP in-a-box solution, designed specifically for Multi-Tenant properties, works great for WISPs too.
paulyb
Mon Dec 21, 2009 10:26 am
I have been trying to find information on using the Dude to do just this, but can not acheive success.
I have an APC UPS connected using USB, I have the UPS Package installed and want to create a Probe to monitor the On-line state. I have read the Probe Thread and other forums but I have been unable to decifer the correct function to read the variable.
Any help greatly appreciated.
Paul
matrot2
Mon Dec 21, 2009 8:57 pm
Paul
From APC UPS work is not convenient if PoE cable length greater than 5 meters.
I am impressed by this:
http://tandem.ck.ua/ups_mtm-eng.php
http://tandem.ck.ua/ups_mt-eng.php
paulyb
Tue Dec 22, 2009 1:30 am
This a good product, but my UPS is within the same enclousure as the router so cable length is fine. I can see all the data in WinBox, but what I am hoping to do is have a Probe Function that can monitor the On-Battery status within the Dude, but I am yet to make it work.
matrot2
Tue Dec 22, 2009 3:01 pm
Mikrotik does not support SNMP UPS.
The answer of the mikrotik:
"Thank you very much for the request.
Currently such options are not available over SNMP, but we added these
features to our todo list."
See scripts:http://tandem.ck.ua/prg/scripts.txt
Maybe they will help you.
We have also used them for APC.
prcek
Wed Nov 10, 2010 11:28 pm
Not everyone uses The Dude, but Zabbix, Zenoss or other NMSs. It would be really handy to have an option to save a value from script as OID. For example count of wireless users (/interface wireless registration-table print count-only where interface="wlan1"). Really handy and useful.
Z.
Chupaka
Thu Nov 11, 2010 1:44 am
or ':put [/queue tree get test-pcq pcq-queues]' - developers promise that it vill be added in future versions, but with that feature we can get it right now =)
janisk
Thu Nov 11, 2010 1:03 pm
that will be added at first for simple queues.
rmichael
Forum Veteran
Forum Veteran
Thu Nov 11, 2010 7:27 pm
For now you can "hack around it" and use currently defined OIDs. For example, simple queue's name has an OID and you can change the name to reflect some value with a script. I also manipulate MTU value, since it's got an OID, of dummy VAP to the same effect. I'm sure you can find others... :)
Chupaka
Thu Nov 11, 2010 11:33 pm
simple?!? who need that??? queue tree ruleZ!
omidkosari
Trainer
Trainer
Mon Oct 31, 2016 1:09 pm
Congratulations
The feature has been added in 6.37
http://wiki.mikrotik.com/wiki/Manual:SN ... s_with_GET
MTCNA , MTCRE, MTCWE, Mikrotik Certified Trainer
amissboy
Mon Jan 02, 2017 9:19 pm
I want to write script for oid ccq .
may help me
Users browsing this forum: bwooce, Easpeak, eworm, Google [Bot], Sob and 125 guests
