taglio
Vlan questiion
Mon Apr 20, 2009 11:43 am
Hi there,
a customer of mine have done me a question that i cannot reply.
It's possible to mark all traffic passing for an interface that don't have a VLAN tag with a new VLAN tag?
Regards.
.mhavoc world
mrz
Re: Vlan questiion
Mon Apr 20, 2009 1:26 pm
Yes you can do it by adding vlan interface.
Chupaka
Re: Vlan questiion
Mon Apr 20, 2009 6:11 pm
..., and then bridging it with ethernet interface, if you do not need routing
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
taglio
Re: Vlan questiion
Tue Jul 21, 2009 5:39 pm
Hi there;
sorry for reopen the POST but my customer haven't find a solution and with the informacion that you have give me also i'm in doubt.
The problem is from 2 to Central.
With RB411A i want to tag traffic untagged that generate the pc with ip 10.158.50.202/24. Traffic from the telephone is already tagged from the same IPTel [VLAN10].
With RB411A i want to "translate" untagged traffic [VLAN1] in VLAN50. This is my configuracion:
RB411A
add name="VCA-Cementerio" protocol-mode=rstp
/interface vlan
add interface=ether1 name="VLAN Usuarios" vlan-id=50
/interface wireless
set wlan1 adaptive-noise-immunity=client-mode band=5ghz country=spain \
	scan-list=5500,5700 mode=station-wds ssid=W-ENLACE-VCA
add bridge="VCA-Cementerio" interface=wlan1
add bridge="VCA-Cementerio" interface=ether1
add bridge="VCA-Cementerio" interface="VLAN Usuarios"
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
add address=10.158.3.244/23 interface="VCA-Cementerio"
X86
add name=bridge1 protocol-mode=rstp
/interface wireless
set 0 adaptive-noise-immunity=ap-and-client-mode band=5ghz country=spain \
	frequency=5500 mode=ap-bridge ssid=W-ENLACE-VCA \
	wds-mode=dynamic wds-default-bridge=bridge1
set 1 adaptive-noise-immunity=ap-and-client-mode band=5ghz country=spain \
	frequency=5700 mode=ap-bridge ssid=W-ENLACE-VCA \
add address=10.158.3.248/23 interface=bridge1
But traffic arrive to the switch D-link DES-3010G untagged [traffic from VLAN10 is OK].
Thank you in advanced,
Best Regards.
.mhavoc world
mrz
Re: Vlan questiion
Wed Jul 22, 2009 9:53 am
bridging vlan interface with physical interface where vlan is added will not work.
taglio
Re: Vlan questiion
Wed Jul 22, 2009 1:05 pm
It doesn't work. VLAN 50 doesn't arrive to central. Anyone can tell me how can i do it?
Thank you in advance.
Best Regards.
.mhavoc world
noam_chom
Re: Vlan questiion
Fri Aug 21, 2009 1:12 pm
Just create Virtual AP interface instead WLAN interface and put it int the bridge :
instead:
put:
add bridge="VCA-Cementerio" interface=virtualAP-wlan1
Regards,
Ilija
Users browsing this forum: Google [Bot] and 74 guests
