honzam
What's new in 3.23
Mon Apr 20, 2009 7:22 pm
What's new in 3.23:
*) fixed installation on fresh disks or VMs;
*) add 802.1ad Service Tag support for VLAN;
*) wireless - fix for RTS/CTS when used together with dynamic ACK timeout;
*) serial ports are now grouped per USB device;
*) added gsm info command to ppp-client;
*) added URL support to fetch tool;
*) added dial-on-demand mode to PPTP & L2TP clients;
*) ssh - now non-interactive console commands can reference variables;
*) fixed TFTP server logging;
*) fixed problem - "/system upgrade" (autoupgrade) did not show proper package
architecture and was unable to fetch new packages;
*) fixed bug - hotspot 'walled garden ip' rules did not work on some boards
after reboot;
*) added '/interface print stats' command;
*) improved support for OSPF as PE-CE routing protocol;
*) added OSPF sham links;
*) fixed a bug in set-bgp-prepend-path routing filter;
*) fixed some MPLS TE reoptimize bugs;
*) added MPLS TE bandwidth management features;
*) netwatch - ignore items with interval 0s, this value was causing
netwatch to fail;
*) routing-test - added new type of gateway argument: ip address together with interface;
*) api - 'disabled' property was not available from api since 3.21, fixed;
*) api - added support for retrieving OID values;
*) api - removed special behaviour of 'find' command under API. Use
'print' command with queries instead of 'find'. This change fixes
scripts that are started from API and contain 'find' command.
*) console - removed support for octal numbers, now string of digits with
a leading zero is interpreted as decimal number;
*) console - added binary ~ operator that matches value against
POSIX extended regular expression;
*) console now accepts decimal numbers with k/K M G T P suffixes for
values of some properties;
*) console - fixed export problems:
if long line is wrapped just before space charater, the space character
has to be escaped, otherwise it is lost;
errors during export generated a comment line that was incorrectly enclosed
in quotes;
*) scheduler - added owner and policy properties; all existing
scheduler entries will get owner name "*sched" and policy
read,write,test;
*) routing-test - allow to specify that route gateway is in the main routing table;
*) added route cache statistics;
*) fixed mesh protocol;
*) graphing - fixed IP address mask display issue for low endian architectures;
LAN, FTTx, Wireless. ISP operator
blt
Re: What's new in 3.23
Mon Apr 20, 2009 8:50 pm
The upgrade again not work...
autoupgrade > refresh = nothing.
This not new :lol:
AHTES
Mon Apr 20, 2009 8:51 pm
Auto Update STILL NOT WORKING
I have tried ROS 3.17, 3.20 and 3.22 on 3 different RB:
no one found 3.23 in ftp server (3.20 is founded).
(sorry for my poor english)
Chupaka
Mon Apr 20, 2009 9:27 pm
as you can see in the first post, it's fixed in 3.23. so 3.23 will be able to recognize and autoupdate to 3.24, 3.25, etc. =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
AHTES
Tue Apr 21, 2009 3:11 am
sorry for my bad english:
3.13 (for example) detect new 3.14, 3.15 ,3.16 ,3.17, 3.18, 3.19, 3.20 but NOT 3.22 or 3.23.
The problem is not in PREVIOUS 3.22 relases, but in new "compressed/compiled" files.
The fact important for user is that OLD version can detect NEW,
not the NEW detect PLUS NEW...
Manually FTP update all 3.13 / 3.20 (i have +300 RB...) at 3.23 is the problem....
normis
Tue Apr 21, 2009 9:08 am
AHTES read again what CHUPAKA posted above ...
blt
Tue Apr 21, 2009 9:47 am
....and after the router will be upgrade automatically Normis ? This really unconfortable more than 20-30 routers ! Please make some patch we can upgrade to 3.23 easy.
normis
Tue Apr 21, 2009 9:54 am
upgrade to v3.23 manually. from then on, the auto upgrade will work.
you can use the Dude to do upgrades too.
you must understand, the fix is in v3.23, your v3.22 has NO FIXES it's still the same as it was.
AHTES
Tue Apr 21, 2009 10:36 am
Ok, i have understand: I must use The Dude, but is possible make in future "Auto Upgrade" in WinBox or "/system update" work again on older version (3.20 and older) ? Obviously the problem is in the npk packages (size? checksum? new format? I do not know... but PARTIAL downloaded npk are founed by auto upgrade...).
Thanks for your works. (And sorry for my bad english)...
normis
Tue Apr 21, 2009 10:39 am
we can't modify your old version. it's not possible, it would require you to reinstall it.
Chupaka
Tue Apr 21, 2009 10:40 am
new npk format - new rake to tread upon =)
p.s. it's hidden advertisement of The Dude! :lol:
AHTES
Tue Apr 21, 2009 11:33 am
This is my last post about that.
I do not wanna be ******.
The point is:
NOT modify OLD version for DETECT NEW,
but MODIFY NEW to be DETECTED BY OLD. (3.13 detect 3.20 ...)
normis
Tue Apr 21, 2009 11:56 am
the old version doesn't understand new packages. we can't teach it.
leequince
Re: What's new in 3.23 (Broken 3G)
Tue Apr 21, 2009 2:54 pm
Since the upgrading to 3.23 no 3G modems work.. USB ports 1 and 2 nolonger show, log states unable to aquire serial port.
I have tested with E220's and E169's alll working correctly with 3.17..
Also tried with fresh clean install no change.
Lee
normis
Tue Apr 21, 2009 3:04 pm
configuration change is needed, see changelog. new wiki will follow shortly.
leequince
Tue Apr 21, 2009 3:22 pm
Ok I understand that is the case due to the GSM-Info note in the log...
Its not very helpful tho that the Wiki Info is not released at the time of the software.. It like driving blind..
Dangerous.
Lee
QpoX
Tue Apr 21, 2009 4:15 pm
Lee
My E180 on x86 still works on 3.23!
normis
Tue Apr 21, 2009 4:25 pm
taglio
Tue Apr 21, 2009 5:04 pm
It's meaning that now we can use AT commands with ppp client connected??
.mhavoc world
Aug
Tue Apr 21, 2009 5:29 pm
AND it installs on my sata drive without a hitch.
Thanks.
Aug
parrini
Wed Apr 22, 2009 9:22 pm
What's new in 3.23:
Can anyone say what was the problem that required this fix and what was the impact?
dawam
Trainer
Trainer
Wed Apr 22, 2009 11:25 pm
What's new in 3.23:
maybe this
http://forum.mikrotik.com/viewtopic.php?f=7&t=29275
Everything looks complicated to begin with, but it's surprisingly simple when you understand it.
parrini
Sat Apr 25, 2009 5:02 am
What's new in 3.23:
maybe this
I am dying to deploy this release because I have lots of hidden clients, but good judgement tells me to wait a few more days :)
mramos
Tue May 05, 2009 6:44 am
FYI:
Huawei E156 3G modem on 3.23:
Command Channel: 2
Data Channel: 0
Info Channel: 1
[mramos@WRAP-3G] > int ppp-client info 3G_NET
pin-status: "READY"
manufacturer: "huawei"
model: "E156"
revision: "11.604.09.01.149"
serial-number: "356368020595709"
activity-status: "call in progress"
functionality-status: "minimum"
gprs-mode: "B - EDGE"
current-operator: "3G_NET"
signal-level: "-95 dBm"
Actually the modem is locked to 3G modes and frequencies (e.g HSDPA/WCDMA @ 2.1GHz). I don't know why ppp-client info reports gprs-mode "B-EDGE" because it's disabled by AT commands and stored on modem flash. Of course a disabled radio (e.g 850MHz) will report a signal-level so low as -95dBm. This modem is quadriband (850, 900, 1800 & 2100 MHz).
With this new aproach to 3G modems on 3.23, it's not possible to use serial-terminal when ppp-client is up. I upgraded from 3.21 to 3.23 and at 3.21 I use to run serial-terminal on USB2 to snif RSSI and other modem info such as TX/RX bytes, up-time, etc.
Where is the WCDMA signal-level reading?
Marcus Ramos
Electronics Technician
(Microwave HW, RF, antennas, propagation)
S.Paulo - Brazil
Users browsing this forum: Adelomer, matiss, yonesmit and 118 guests
