normis
Newsletter #17
Wed Apr 22, 2009 2:00 pm
http://www.mikrotik.com/pdf/newsletter17.pdf
* Wake on LAN
* Logging to file
* Two new RouterBOARD products
* new Support request form
omega-00
Re: Newsletter #17
Wed Apr 22, 2009 4:56 pm
Hello normis, are you able to link us to any further information on the WOL implementation?
I'm running ROS v3.23 x86 and the command doesn't appear under the /tools list
Also, is this going to be included in the system package or under advanced tools? (I have both on this device at the moment, but wanted to know as this wasn't mentioned in the newsletter)
mushmx
Re: Newsletter #17
Wed Apr 22, 2009 4:59 pm
Yeah, I have the V3.23 and the same don't appear the tool WOL :? . But anyway it a great news :D
normis
Re: Newsletter #17
Thu Apr 23, 2009 8:47 am
I think it's going to be in the next version. the tool is a very standard WOL tool, specify the MAC and it just sends the MagicPacket (UDP) to broadcast address. It doesn't support SecureOn (password based).
jp
Long time Member
Long time Member
Re: Newsletter #17
Fri Apr 24, 2009 3:02 am
Thanks for the WOL; I look forward to it!
nz_monkey
Re: Newsletter #17
Fri Apr 24, 2009 3:32 am
come on Newsletter #18 with RB616 ;)
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet FTCNA, FCNSP, FCT | Extreme Networks ENA
rmichael
Forum Veteran
Forum Veteran
Re: Newsletter #17
Fri Apr 24, 2009 8:45 am
Why are there two power jacks on rb450G?
Chupaka
Re: Newsletter #17
Sat Apr 25, 2009 12:49 pm
redundant power supply? =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
macgaiver
Re: Newsletter #17
Tue Apr 28, 2009 12:55 pm
I would say parallel - if same voltage both will be used at 1/2 all the time, but if 1 dies other will take full load (so there is some kind of redundancy)
With great knowledge comes great responsibility, because of ability to recognize id... incompetent people much faster.
Ibersystems
Re: Newsletter #17
Thu Apr 30, 2009 6:12 pm
this is true¿??
Martín
martinruiz at ibersystems.es
Experto en redes WiFi y enlaces WiFi.
Facebook: @Ibersystems
Twitter: @Ibersystems
Certified in Traffic Shaping, Wireless, Internetworking, Routing and User Management.
MTCTCE - MTCWE - MTCINE - MTCUME - MTCRE
roc-noc.com
Forum Veteran
Forum Veteran
Re: Newsletter #17
Fri May 01, 2009 5:04 pm
this is true¿??
Not true. If you plug two power supplies into this, they will fight each other until at least one dies. You never want to connect the outputs of two DC power sources in parallel. Systems with redundant power supplies have additional circuitry that keeps them isolated from each other.
I think the reason for the 2nd power jack is so you can build it into a rack mounted case and have the power supply inside the case and use an external standard computer power cord. (Like the RB1000U.)
Tom
http://www.roc-noc.com
Tom, CCNA, ISP, USA Mikrotik Distributor
888-762-5662
Ibersystems
Re: Newsletter #17
Mon May 04, 2009 11:14 am
Dear Mikrotik support,
can you explain us wich is the reason of the 2nd power connector?
Thanks!
Martín
normis
Re: Newsletter #17
Tue May 05, 2009 9:19 am
yes, it's to use with a different case where you don't want the plug to be hanging out of the front. like a rackmount for example.
Ibersystems
Re: Newsletter #17
Tue May 05, 2009 11:05 am
Where is this rackmount case?
In Made for mikoritk section?
Thanks,
Martín
normis
Re: Newsletter #17
Tue May 05, 2009 11:39 am
I don't know :) there is no specific case, i'm just talking about "if you want to"
Ibersystems
Re: Newsletter #17
Tue May 05, 2009 12:09 pm
Oks,
thanks!
Martín
lizard79
Re: Newsletter #17
Tue Jun 09, 2009 5:04 pm
hi. Does wol command work for anybody? I have two installations of rb100 and rb133 with routeros 3.24, but i'm unable to wake up computers using this wol coomand. I have separate linux machine on the network instaled and wol from this is working fine...
jp
Long time Member
Long time Member
Re: Newsletter #17
Wed Jun 10, 2009 4:57 pm
Doesn't work for me yet.
Here is a 3.24 433.
  MikroTik RouterOS 3.24 (c) 1999-2009       http://www.mikrotik.com/
Property of Midcoast Internet Solutions 2075948277 or www.midcoast.com
Unauthorized access will be prosecuted.
All Access is logged.
[admin@111Lucia] > ip address print
 #   ADDRESS            NETWORK         BROADCAST       INTERFACE
 0   69.39.102.36/27    69.39.102.32    69.39.102.63    ether1
 1   10.0.54.1/24       10.0.54.0       10.0.54.255     ether2
 2   10.3.25.1/24       10.3.25.0       10.3.25.255     ether3
 3   10.3.26.1/24       10.3.26.0       10.3.26.255     ether3
 4   192.168.1.2/24     192.168.1.0     192.168.1.255   ether2
 5   10.0.27.250/24     10.0.27.0       10.0.27.255     ether1
 6 D 10.4.2.4/32        10.4.2.1        0.0.0.0         pptp-out1
[admin@111Lucia] > /tool wol 00:19:DB:62:7B:FB
This is supposed to start something on ether2. I'm suprised WOL doesn't need to specify an interface to send the magic packet to. It doesn't increment any firewall counters, so I doubt it's that.
This is what I use on my PC to accomplish the WOL.
jp@xj13:~> more /usr/local/mis/bin/e-type
#!/bin/bash
/usr/bin/wakeonlan 00:19:DB:62:7B:FB
echo E-type has been started.
jp@xj13:~>
rlima
Re: Newsletter #17
Mon Jul 27, 2009 4:22 am
As far as I know WOL still not working.
Somebody know when it will be able.
Many thx, Ricardo
tgrand
Long time Member
Long time Member
Re: Newsletter #17
Wed Jul 29, 2009 3:18 pm
It is possible that perhaps an arp entry must exist for the MAC.
normis
Re: Newsletter #17
Wed Jul 29, 2009 3:20 pm
maybe somebody can use a sniffer and capture the stream from the WOL packets that don't wake that PC? and maybe also the stream from a working non-MT solution to the same PC?
rlima
Re: Newsletter #17
Thu Jul 30, 2009 8:25 am
The MAC of the machine I am traying to wake up is in the ARP list.
When i make a Packet Sniff there is no packet
I wiil send to suport an email with the cap
Bye Ricardo
jp
Long time Member
Long time Member
Re: Newsletter #17
Mon Aug 03, 2009 8:29 pm
[admin@111Lucia] /file> /tool wol 00:19:DB:62:7B:FB
is what I do. Nothing gets captured when I sniff according to the following setup:
[admin@111Lucia] /file> /tool sniffer export
# aug/03/2009 13:20:30 by RouterOS 3.25
# software id = Z6DV-8JR8
/tool sniffer
set file-limit=1000 file-name=wolcap filter-address1=0.0.0.0/0:0-65535 \
    filter-address2=0.0.0.0/0:0-65535 filter-protocol=all-frames \
    filter-stream=no interface=ether2 memory-limit=100 only-headers=no \
    streaming-enabled=no streaming-server=0.0.0.0
This command is on opensuse linux using wakeonlan v0.41 according to -v usage or 1.4.2.3 according to the top of the perl program file.
jp@xj13:~> cat /usr/local/mis/bin/e-type
#!/bin/bash
jp@xj13:~>
The capture file is attached from the following command:
tcpdump -n -i eth0 src or dst not 10.0.2.4 -w capture.txt
I was ssh'd in from 10.0.2.4 so that why that's excluded.
Also attached is a screenshot of the wakeup packet from that capture displayed in wireshark.
I wonder if routerOS is sending the command to the wrong interface? My lan is on ether2.
xezen
Long time Member
Long time Member
Re: Newsletter #17
Mon Aug 03, 2009 8:39 pm
i have ther same problem pc connected to the rb works fine
but pc connected to swicth were rb is connected to works 60%
if more ther 3 eth are connected
and pc connected to rb 70% of the time it works
if 3 eth are connected to switch and rb to switch 30% of the timer it works
If i dont No Ask someone That Does!
Users browsing this forum: Google [Bot], MSN [Bot], sindy, Technetium and 92 guests
