MUM Europe 2020
Pepo
Limit Some Connections Speed
Mon May 25, 2009 4:47 am
hi all,
I'm using mikrotik, really it is so fine with me.
but now i need to limit some connections whitch destinied to some porn sites.
what i need is to let that connection to that site is soo slow, also when it show an online .flv file, that file will be so slow.
Really i need to that, i don't need to make that site off of my network, because i don't need to let the users know that i cause that problem.
what i need is to kill that connection by slow data rate.
thanks...
:lol:
jimbojones
Re: Limit Some Connections Speed
Fri May 29, 2009 5:07 am
Use an external proxy such as Squid, with Delay pools.
Jimbo
normis
Fri May 29, 2009 3:37 pm
or you can make "simple queue" to that specific IP of the server.
thebest1
Sat May 30, 2009 4:49 pm
May please tell me how to make it step by step :D
jimbojones
Sat May 30, 2009 9:06 pm
If you want to use a simple queue, then go to http://wiki.mikrotik.com/wiki/ and search on the term "simple queue"
If you want to do it via delay pools, google squid delay pools.
We can't do it all for you now :)
Jimbo
Pepo
Sat Jun 06, 2009 6:26 am
Thanks for all,
but what i need is to slow the connections that go to porn sites. :lol:
so, how can i do that ???
dormador
Sat Jun 06, 2009 9:16 pm
if mikrotik do that ....thats will be great .
the porn sites are dangers for our family , mankind and decencies ..
really we need to do some thing for these sickening web site .
Chupaka
Sun Jun 07, 2009 3:38 am
if you can make a clear rule to define 'porn site'...
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: Google [Bot], MSN [Bot], thobias, ugisduc and 59 guests
