bozok
conecting 5211 and 5213
Mon May 23, 2005 7:36 am
i used atheros 5211 with routerOS 2.8.11 and connect to atheros 5213 with routerOS 2.8.26
Using band 5 Ghz. The distance between those two radio are 7 km.
basic-rates-a/g=6Mbps,9Mbps for the two site.
When i used the bandwidth-test, i have total traffic up/down around 6Mbps.
The ping between those two are ok. Around 20 ms.
But the problem begin when i connect those two site with real traffic, which has traffic arround 4 Mbps. The ping are increase until 200 ms.
What is the problem ? It's only 4 Mbps traffic, still under 6 Mbps.
the_time
Mon May 23, 2005 4:17 pm
I have the same problem conecting 5212 and 5211 on 2.5 Mbps have huge pings .
Very greatfull in a solution .
tully
Mon May 23, 2005 5:41 pm
The basic rate is used for link maintenance -- set it back to 6Mb/s and then leave the supported rates to all of the rates.
Or reset the entire config and start ove.
John
mip
Mon May 23, 2005 7:10 pm
Set data rates max of 12 or 18mbps, and leave basic rates 6mbps as tully said.
https://www.youtube.com/watch?v=j7q0Y_JZMrg - the country you must visit
Users browsing this forum: No registered users and 138 guests
