stephenpatrick
Forum Veteran
Forum Veteran
2.9 RC 4 ....
Mon May 23, 2005 3:30 pm
posted and coming down the wire ...
CableFree - Wireless Excellence - Microwave, E-band Radios, Free Space Optics, High performance Radios & Routers
http://www.cablefree.net
stephenpatrick
Forum Veteran
Forum Veteran
Mon May 23, 2005 3:31 pm
from the changenotes:
What's new in 2.9rc4:
*) fixed via driver for RB500;
What's new in 2.9rc3:
*) fixed radius-mac-authentication bug in wireless;
v1nt3r
Mon May 23, 2005 7:10 pm
Up and running on 4 base stations ;-)
No problems (as with rc1 and rc2), but wireless settings is lost after reboot.
csickles
OOPS !!
Tue May 24, 2005 12:59 am
Installed on PC = Great... :D
Installed on RB500 and BOOM! No kernal.. :shock:
Have sent msg to support, expect to here about fix tonight... :wink:
So I am batting about 500.. Hmmm strange...... :?
Craig
Things that make you go "Hmmmmmmmm"...
Craig
stephenpatrick
Forum Veteran
Forum Veteran
Tue May 24, 2005 10:16 am
Put it on 3 high-speed test routers yesterday (1 to 1.5GHz CPUs, 3 different types) and it seemed perfectly stable in wired throughput tests (98Mbps ethernet to ethernet). Not tested with Wireless yet.
Regards
Ultanium
Tue May 24, 2005 12:48 pm
Working fine on a Dell 400SC server on our backbone, 7 miles away from our tower. 70 subs running off the tower, rc4 throttling and addressing them all with no problems so far. I did notice after the move from 2.8 to rc2, the queue display is alot more sluggish than before, was the refresh rate turned down a little in 2.9? Also, would someone mind zipping and sending me the original html files? I screwed up and accidently deleted them all and the folder they were in....
Tommy J.
rickard
Tue May 24, 2005 2:16 pm
RC4 Working fine on 4 base RB532 routers. and i think the problem with the wlan card loses the clients is gone :-)
Syonyk
Tue May 24, 2005 6:41 pm
Installed on a Via based router box with Atheros card, and I get the following errors when trying to ping the wireless IP:
92 bytes from 10.0.1.1: Dest Unreachable, Bad Code: 9
Vr HL TOS Len ID Flg off TTL Pro cks Src Dst
4 5 00 0054 c392 0 0000 40 01 a018 10.0.1.254 10.0.1.1
//EDIT: I just downgraded the router to 2.8.27, and everything is working properly, so...
//EDIT2: More info would probably be useful. The wireless card is reported in 2.8.27 as an Atheros AR5213, and I tried several B/G/combo settings, with no change.
-=Russ=-
Ultanium
Wed May 25, 2005 10:58 pm
Just found another possible issue. Try dragging your queues around a little. About every 10th move, it will completely lose it's information in that queue.
I was trying to get all of mine in numerical order by IP and lost 3 of them...
Tommy
randyloveless
Thu May 26, 2005 10:54 am
rc4 issue ? i added some dst-nat rules and for some reason the router will not allow me to move them up or down.
did not have this issue in rc2. this is on a p4 system not that it matters.
any one had this issue.
randy
rickard
Thu May 26, 2005 11:57 am
Problems with RC4 the clients get conected every 25 seconds ??
but it works:-) my log is full with wlan conected.
i will send the supout file.
OrCAD
Thu May 26, 2005 4:04 pm
OS2.9rc4
I have unchecked "default Forwarding" in wireless interface menù but registered client still to comunicate with each other!!
Is a bug?
thanks
dean-za
ip pool big
Thu May 26, 2005 6:29 pm
If you add an ip pool and dont select any ip the winbox app crashes.
Dean
Users browsing this forum: Znevna and 85 guests
