dormador
hotspot+VPN is it possible
Fri Jun 05, 2009 6:39 pm
Hi all
really this post for one query... the query is can we make pptpclient + hotspot !
i mean our clients contact MK withe normal hotspot .. and the MK communicate them to pptpclient...
sample quistion like you see.. :D
any idea gentleman
regards
Chupaka
Re: hotspot+VPN is it possible
Fri Jun 05, 2009 11:00 pm
of course
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
dormador
Sat Jun 06, 2009 8:30 pm
thanks Mr.Chupaka for your helpful ..
this philanthropy Ethics which we need in this forum .
dormador
Sat Jun 06, 2009 8:54 pm
never accept domain name !
whats the problem or the solution ?
thanks
Chupaka
Sun Jun 07, 2009 2:38 am
when adding pptp-client with domain-name, the name is being resolved into IP address. so you need to setup DNS in /ip dns
if you need to use domain name due to changing IP address of the pptp server, you should setup scheduler to run script which will be resolving text name to ip address and changing your pptp client
p.s. ask definite questions - you will receive definite answers. the answer to the question 'are we alive?' is 'yes', nothing more
Users browsing this forum: kd2pm2 and 174 guests
