MUM Europe 2020
Krusty
firewall rule to dst host
Tue Jun 09, 2009 5:03 pm
Hello everybody,
I got simple question. is there any chance to add firewall rule to DST host not to DST IP
example
I need to add this rule
add action=accept chain=forward comment="" disabled=no dst-address=217.31.55.217 dst-port=40000-50000 in-interface=eth2-LAN out-interface=eth1-WAN protocol=tcp src-address=192.168.1.0/24
BUT instead of dst-address=217.31.55.217 I need to add HOST update.atlascon.cz
Is this possible?
THX lot
NAB
Trainer
Trainer
Re: firewall rule to dst host
Tue Jun 09, 2009 5:59 pm
Yes, but not directly. You'll have to write a script which resolves the hostname and updates the firewall rule accordingly. You'll then have to schedule the script to run regularly.
Nicholas Barnes BSc(hons)
Certified Mikrotik Consultant
Certified Mikrotik Trainer
Vitell - Asterisk, Linux and network consultants
Unofficial IRC channel: #routerboard on irc.z.je
Krusty
Tue Jun 09, 2009 6:16 pm
Thanks, but this is unnecessarily complicated :(
In the future, will be any chance to make setup simpler ? like some command (dst-host) or something like this?
changeip
Tue Jun 09, 2009 6:41 pm
if you want complicated then tell the router to resolve that hostname for every single packet that traverses that rule. ouch.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
NAB
Trainer
Trainer
Wed Jun 10, 2009 1:32 pm
...this is unnecessarily complicated
On the contrary, this is necessarily complicated. How do you think it should be done (bearing in mind changeip's comments about resolving the hostname for every packet)?
normis
Wed Jun 10, 2009 1:37 pm
yes, if you have 500 firewall rules (as many do) and each packet that is directed to some host needs to cause a DNS resolve request, your router will just go insane :)
Chupaka
Thu Jun 11, 2009 1:20 pm
but MT may internally implement something like the script mentioned above: periodically check for IP address changes for selected DNS names and correct firewall rules accordingly
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Krusty
Thu Jun 11, 2009 5:57 pm
this is great idea
may be someone so nice and write me this script?
I would be very grateful
NAB
Trainer
Trainer
Thu Jun 11, 2009 6:30 pm
...periodically check for IP address changes for selected DNS names and correct firewall rules accordingly
Thinking about this, this could be quite easy to implement from our side rather than on the MT side.
If we create an address list entry for every host we want to query in this way and refer to the address list in the firewall rules, then all we need to do is write a script which runs periodically (say every hour) to update the address list with the correct address. For example:
/ip firewall address-list add address=0.0.0.0 comment=www.mikrotik.com list=host_mikrotik
/ip firewall filter add chain=output dst-address-list=host_mikrotik action=reject
and then a script which updates every address from the address list which starts 'host_' with the IP address of the host mentioned in the comments:
# define variables
:local list
:local comment
:local newip
# Loop through each entry in the address list.
:foreach i in=[/ip firewall address-list find] do={
# Get the first five characters of the list name
  :set list [:pick [/ip firewall address-list get $i list] 0 5]
# If they're 'host_', then we've got a match - process it
  :if ($list = "host_") do={
# Get the comment for this address list item (this is the host name to use)
    :set comment [/ip firewall address-list get $i comment]
# Resolve it and set the address list entry accordingly.
    :set newip [:resolve $comment]
    /ip firewall address-list set $i address=$newip
That makes it very easy and quite flexible.
Except... If the host name doesn't exist, the ':resolve' action fails, the whole script dies and nothing after that entry gets changed. I've mentioned this before and (in my opinion) this is a fundamental flaw in the design of the ':resolve' action. I believe that it should return '0.0.0.0' or 'unknown' or something which we can then test for within the script. Just because a hostname doesn't resolve, doesn't mean there's anything wrong - I would like to be the judge of whether or not to crash out rather than have the router arbitrarily decide for me.
Anyway, rant over. I think this is quite an elegant solution to the problem.
Krusty
Fri Jun 12, 2009 10:41 pm
[quote="NAB"][/quote]
flawless, seems to work perfectly
thanks lot
NAB
Trainer
Trainer
Tue Jun 16, 2009 3:42 pm
Users browsing this forum: lamclennan, nowinskit, PwFactor and 102 guests
