MUM Europe 2020
dlabreu
aggregate links, how?
Tue Jun 16, 2009 5:19 pm
Hi There.
I am working on one project , that i will have to do internet agregation, and i don't know how to do it.
Wend i went to the Mk Course in JHB South Africa , the teacher told us that is possoble , but he didn't told us how to do it.
So i hope you guys can help me on it.
I have one Mk bord 433 , with 2 four mega link on it , one 4 mega line is plug into eth2 and the other is plug into eth3 , and eth1 is for my internal network.
I want to aggregate this 2 four mega links that i got and make one 8 mega link.
Am i able to do this with my Mikrotik Bord , and if i am how?
eg:
ETH2 4mb link _______
-------------------| | Eth1 Local Network
ETH3 4mb link |MK 443 |----------------------
-------------------|_______|
Thanks alot.
Daniel Abreu
Daniel Abreu.
Nuke
Re: aggregate links, how?
Tue Jun 16, 2009 5:51 pm
It doesn't work correctly, its starts dropping packets after a while. But you can play with it using nth terms in mangle rules. Then get a routing mark from those mangle rules to do your routing from.
Not going to go into the details, its anyway not working well. Here is the wiki guide http://wiki.mikrotik.com/wiki/NTH_load_ ... masquerade
NAB
Trainer
Trainer
Tue Jun 16, 2009 6:04 pm
Is this for NAT/masquerading only, or does it apply to direct connections too?
Nicholas Barnes BSc(hons)
Certified Mikrotik Consultant
Certified Mikrotik Trainer
Vitell - Asterisk, Linux and network consultants
Unofficial IRC channel: #routerboard on irc.z.je
Nuke
Tue Jun 16, 2009 6:11 pm
It shouldn't have anything to do with NAT, I did a ping from the mikrotik that was doing the loadbalancing, and it started dropping pings after anything from 30s to 3min. When testing over 4 lines, after a while, it only replyed once in 4 pings, and I could see only one line recieving pings back(using tourch).
fatonk
Tue Jun 16, 2009 6:37 pm
Post your configurations, and lets see what is wrong with it, otherwise I had no problem with such scenarios of link aggregation. Now the PCC feature should solve the problem.
Regards
Faton
Users browsing this forum: almdandi, Bing [Bot], Gombeen666, Google [Bot], oskarsk and 72 guests
