MUM Europe 2020
songyapeng123
r2n POWER WhY IS 20db not 25db
Sat Jun 20, 2009 5:30 pm
I bought a r2n , but in the winbox ,THE biggest power shows 20db, why? the sheetdata is 25DB, Please tell me!!
ste
Re: r2n POWER WhY IS 20db not 25db
Sun Jun 21, 2009 12:26 pm
MT announced to give better transmit-power readings for .n in next beta.
R2N is different as it has 2 channels.
Stefan
tgrand
Long time Member
Long time Member
Wed Jul 08, 2009 3:11 pm
2 channels would indicate a hit of half power = ~3db
This would indicate that 22db should be available.
If I am wrong please educate us as to why this would not be true.
janisk
Thu Jul 09, 2009 2:54 pm
connect both antennas and configure your card accordingly for maximum output power.
also, check your regulatory domain settings and limitations in local laws.
normis
Thu Jul 09, 2009 2:55 pm
both chains have to be selected, for the correct power to be shown.
popcorrin
Thu Sep 09, 2010 7:00 pm
Can you please explain this for me. The spec sheet shows that for 802.11 g this card has a power rating of 25db. In order to get it to transmit at this power you have to select both chains even though 802.11 g is single chain? And if you don't have an antenna connected to the 2nd chain, you will damage the card?
popcorrin
Sun Sep 12, 2010 12:37 am
the given power is the maximum power. maximum power can be achieved by using both chains. 802.11g is an inferior technology, it can't use both chains like 802.11n so it doesn't work at cards potential maximum
with one chain, roughly 3dbm less will be possible.
That's confusing. According to the spec sheet, the power output drops 2db's for 802.11n when compared to 802.11g.
uldis
Mon Sep 13, 2010 2:24 pm
in each data-rate the tx-power could be different - that is normal.
popcorrin
Tue Sep 14, 2010 5:36 pm
Okay, just explain to me how to get the card to transmit at 24dBm for 802.11g 6Mbit like the spec sheet says it can. If it's not possible then the spec sheet needs corrected.
uldis
Wed Sep 15, 2010 1:48 pm
Enable both chains (connect both antennas) and then observe the tx-power section - you will see that the total power is 24.
popcorrin
Wed Sep 15, 2010 5:01 pm
Enable both chains
? Then it's no longer 802.11g.
normis
Thu Sep 16, 2010 8:16 am
yes it is. only both antennas will be used together, as one antenna.
jrecabeitia
Fri Sep 17, 2010 2:43 pm
Normis, then with N plates must be used only dual antennas for maximum performance, regardless of the selected standard. Right?
normis
to have maximum power, yes
Users browsing this forum: Google [Bot], LinusN and 131 guests
