yakcora
web server behind mikrotik internal userscannot browse site
Tue Jul 07, 2009 6:55 am
Hi
I have a web server behind a Mikrotik hosting http://www.xyz.com
people can browse the http://www.xyz.com if they are OUTSIDE my network
but no one can browse the http://www.xyz.com if they come in to my network
if I do not define the out-interface on masquerade it works but then a whole new box of baaaad stuff happens with other stuff
here is my setup
dsl with dynamic ip with changeip service
my mikrotik web interface is on port 88
add disabled=no interface=eth1-LAN type=internal
add disabled=no interface=eth3-DSL type=external
add action=dst-nat chain=dstnat disabled=no dst-port=80 in-interface=eth3-DSL protocol=tcp to-addresses=192.168.99.250
add action=dst-nat chain=dstnat disabled=no dst-port=80 in-interface=eth1-LAN protocol=tcp to-addresses=192.168.99.250
add action=masquerade chain=srcnat disabled=no out-interface=eth3-DSL
Oh I have only one IP ...
Chupaka
Re: web server behind mikrotik internal userscannot browse site
Wed Jul 08, 2009 12:51 am
four solutions, the first one is the best =)
1) you may use split-DNS, so that your internal users receive server's internal address
2) you may use web-proxy in MT, just set static entry in /ip dns for your sitename and internal address
3) move your server's address to another IP subnet
4) simply add src-nat rule, as you cannot dst-nat to the same subnet
p.s. yahooo!!! it's my 2009'th post on The Forum :D
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 99 guests
