MUM Europe 2020
astounding
Is there any way to... (firewall and bridge question)
Thu Jul 23, 2009 8:14 pm
Is there any possible way to determine within a firewall chain the physical interface a packet entered IF that physical interface belongs to a bridge?
So far as I can tell by experimentation, this is impossible. The "in-interface" only matches the bridge interface.
Any ideas? Pointers?
Thanks!
Chupaka
Re: Is there any way to... (firewall and bridge question)
Thu Jul 23, 2009 11:14 pm
look at 'in-bridge-port' and 'out-bridge-port'
if not - check that /interface bridge settings set use-ip-firewall=yes
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Fran66
Sat Dec 25, 2010 12:09 am
Those options for some reason doesn't work, can someone address this problem?
Chupaka
Sat Dec 25, 2010 6:32 pm
what version of ROS do you use?
Users browsing this forum: MSN [Bot] and 112 guests
