MUM Europe 2020
rebel2234
X86 Losing config after card replace
Thu Jul 23, 2009 8:37 pm
After replacing a wireless card in an x86 machine running ROS-3.27 the table for that wireless interface is reset to default. How do I keep this from happening? Sorry for the Newb question.
normis
Re: X86 Losing config after card replace
Fri Jul 24, 2009 12:21 pm
this is designed to be so, because when you will put the old card back, it will have the old config. config is bound to card, not slot. what you can do, is "/wireless export file=name" and then "/import name" after card replaced
Users browsing this forum: Google [Bot], inteq, lastovsky, odalsoft, paulororke, r00t and 169 guests
