MUM Europe 2020
karo84
Route For pptp secret
Fri Jul 24, 2009 2:21 pm
Hello
I'd like to know if it is possible to add some route for pptp user.
Here some the setup.
[as@xxsx] > ip ad print
# ADDRESS NETWORK BROADCAST INTERFACE
0 192.168.101.1/24 192.168.101.0 192.168.101.255 ether1
1 192.168.150.129/25 192.168.150.128 192.168.150.255 ether2
Client is connecting with pptp to interface ether2 and getting some Ip address, say 10.10.10.3. and NOT receiving Default Gateway from MT.(We do not need to receive default GW from PPTP Server). I have some machine connected to the interface ether1 with ip address 192.168.101.5/24 and GW 192.168.101.1.
I have tried to add route for pptp secret but there was no result.
Question. How to make pptp client to connect and get ping with 192.168.101.5 without getting default GW from PPTP Server (ROS 3.20).
Thanks With Best Regards
Karapet Aznavuryan
changeip
Re: Route For pptp secret
Fri Jul 24, 2009 7:08 pm
the client will not get anything from the server except its ip address. Windows PPTP server supports classless routing via dhcp, however, Mikrotik does not. You have to enter a static route on the client manually. If using windows you can use the -P to have it saved across a reboot.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
karo84
Fri Jul 16, 2010 9:33 am
Thanks For Reply, I have done already static route with -p option
Users browsing this forum: arnoldmikro, Google [Bot] and 127 guests
