karo84
Detect Ip conflict with ROS
Wed Aug 05, 2009 1:38 pm
Hi!
How To Detect and log the mac address of the bad host, which has the same IP with MT ROS. ?
Please Help Me, It's urgent.
Regards
Karapet
mrz
Re: Detect Ip conflict with ROS
Wed Aug 05, 2009 1:40 pm
You can connect windows machine somewhere in your network, if there is IP conflict windows will tell you :).
I don't know any methods how you can do it with RouterOS
karo84
Wed Aug 05, 2009 1:52 pm
When using Cisco it logs duplicated Ip Address.
But I want To have some method To log the Duplicated Ip with ROS.
atari800xl
Sun Jan 03, 2010 2:48 pm
Hello,will Windows tells,which IP adress is in conflict ?
thank you for answer
guille4
Sun Jan 03, 2010 4:36 pm
feature request!... something like this:
http://ipwatchd.sourceforge.net/
:D
butche
Trainer
Trainer
Sun Jan 03, 2010 9:46 pm
Hi!
If you have a CURRENT problem, do this:
  • Pick an available IP address in the range that has a suspect/known duplicate
  • Assign the above IP address to the interface on the MT that faces that network
  • Remove or disable the IP address on the device that is SUPPOSED to have that IP
  • Do: "/ip arp remove [find]" on the Mikrotik(it is not NECESSARY, but helpful sometimes)
  • Attempt to ping the IP that is duplicated. IT WON'T MATTER IF IT RESPONDS
  • If the IP is truly duplicated, you will find the MAC address of the offending device in the ARP table (even if it did not respond to the ping)
  • Restore the IP on the device that is supposed to own that address
Butch Evans
Mikrotik Certified Trainer
Mikrotik Certified Consultant
BLOG: blog.butchevans.com
http://store.wispgear.net/
butche
Trainer
Trainer
Sun Jan 03, 2010 9:47 pm
Something like arpwatch would be more useful, IMO.
Butch Evans
guille4
Mon Jan 04, 2010 4:40 am
Yes. Arpwatch is better.
SiB
Wed Sep 12, 2018 5:24 pm
Tool > IP Scan
Search double entry in Address column:
Tool > Ping
Arping give you a double MAC in seq number:
You can do a testing via scripts and that way detect a conflict automatical.
My way is add a script into DHCP Server who check every new lease and alarm me via e-mail.
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | WebChat: Tokonda
WinBox Tip: F6 works as ALT+TAB
Users browsing this forum: No registered users and 23 guests
