MUM Europe 2020
cmurrayis
Rb411AH Bridge Issues
Fri Aug 07, 2009 5:42 am
I am having issues setting up my new Rb411AH, The setup is as follows:
I can conenct to the unit without any problems and ocnfigure it, I connect to the remote AP without any issues I assign an IP to the wifi card and can ping across the link no problems.
the problem is when I bridge the Eth1 and wlan1 I cannot pass any traffic across the unit to the remote AP whole network is 10.0.0.0/24, even the unit cannot ping the remote AP as soon as i disable to bridge the unit is able to ping the remote AP.
I know this should work as the remote AP is setup the same with 2 wifi card bridged.
Anyone have any ideas why this would stop working, I have tried 3 different routeros versions :S
Cheers in advance
Cameron
savagedavid
Trainer
Trainer
Re: Rb411AH Bridge Issues
Fri Aug 07, 2009 9:12 am
You cannot bridge a wireless interface running in Station mode. You need to use station-pseudobridge or station-pseudobridge-clone. Alternatively you can use station-wds mode with wds enabled on the AP.
savagedavid
MTCE+T (MikroTik Certified Everything + Trainer)
MikroTik support and training in South Africa
http://www.mikrotiksa.com
david [at] mikrotiksa dot com
cmurrayis
Fri Aug 07, 2009 10:40 am
Cheers for that!
Have never come across that issue before :)
Cameron.
Users browsing this forum: AndreLD, Google [Bot] and 121 guests
