dawam
Trainer
Trainer
RouterOS V3.28 release
Fri Aug 07, 2009 5:57 pm
What's new in 3.28:
*) fixed hotspot problem - on multi-processor systems it was not possible
to set IP address for hotspot client during login - deadlock did happen;
*) fixed hotspot problem - it was possible for hotspot to spike CPU usage
to 100% and not to accept new logins during that time;
*) added ethernet broadcast support for WakeOnLan tool;
*) api - value of 'comment' property was only returned from 'system' package
programs;
*) to see actual values of sensitive configuration parameters (such as
passwords), user needs to possess policy 'sensitive';
*) avoid problems with western time zones by always advancing clock on
startup past january 2st 1970, 00:00:00 UTC;
*) added 'run-after-reset' argument to 'reset-configuration' command. It
allows to specify name of console script file to run after the
configuration reset reboots the router. When this argument is used any
other default configuration scripts are ignored.
*) route - fixed a crash;
*) routing-test - fixed OSPF routing table calculation;
*) send keepalives every 30s (was 3 min) on ppp clients - make some 3G connections
more stable;
*) routing-test - changed BGP network and default-originate behaviour;
*) web proxy - allow to edit error page;
*) console - terminal window size change now does not trigger full terminal
reset;
*) mesh protocol - improved loop prevention (becomes incompatible with earlier versions);
Everything looks complicated to begin with, but it's surprisingly simple when you understand it.
perit
Re: RouterOS V3.28 release
Fri Aug 07, 2009 7:28 pm
What changed exactly ?
Chupaka
Fri Aug 07, 2009 10:10 pm
joining the question. it would be nice if MT could write more detailed changelog, at least for published changes =)
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
duvi
Sat Aug 08, 2009 1:54 am
Was anything changed regarding power handling on x86?
The previous versions were unable to power off the system, but in v3.28 System/Shutdown finally does turn off the computer (:
NetworkPro
Wed Aug 19, 2009 4:10 am
What's new in 3.28:
I think this messed ECMP with PPPoE interfaces. Automatic fail-over is not working - now when a single participant in an ECMP route is gone - the whole ECMP route is declared Network Unreachable. This invalidates a lot of setups.
wiki.mikrotik.com/wiki/NetworkPro_on_Quality_of_Service
Chupaka
Thu Aug 20, 2009 3:39 am
still please comment, what changed in BGP...
nemka
Tue Sep 01, 2009 2:20 pm
Dude v2.2 can get bit rate data from ROS v3.28 with snmp only.
Bit rate graph "freezed" when mastering type is routeros.
Is it a bug or a feature? ;)
I found the answer here: http://forum.mikrotik.com/viewtopic.php?f=8&t=32175
jf77
Fri Sep 11, 2009 1:03 pm
Well, well, well. New shiny version and the broute is still missing... Many "improvements" and many new bugs...
mrz
Fri Sep 11, 2009 1:05 pm
broute was removed few versions ago and will not be added back because it never worked correctly.
jf77
Fri Sep 11, 2009 1:13 pm
It's your standard ansver, but it's no true... As I see it, you removed one functionality and you didn't offer any (functional) replace. It's cheating with customers.
Users browsing this forum: No registered users and 57 guests
