awacenter
RADIUS accounts by volumme
Tue Jun 07, 2005 7:10 pm
I test the MT RADIUS attributes:
Recv-Limit - total receive limit in bytes for the client
Xmit-Limit - total transmit limit in bytes for the client
and they don't work. Moreover, section AAA don't appear in the v2.9 manual. May it be possible ??? I want to create volumme prepaid accounts in RADIUS.
gianluca
Tue Jun 07, 2005 9:11 pm
We successed in 2.8, and we are planning to move to 2.9, hope there is no problem, please post if you have any solution. thanx
Syonyk
Thu Jun 16, 2005 9:41 pm
Have you confirmed that they're being sent from the RADIUS server? I suggest using the radtest utility (if you're running on Linux) to check.
Also, if you're using 2.9, the Rate-Limit attribute is MUCH more flexible, and works with Hotspot/PPPoE/pretty much everything.
I suggest grabbing the Mikrotik dictionary file and giving that to your RADIUS server. It solved several goofy problems I was having.
-=Russ=-
Users browsing this forum: andrejtom, kocouj1, Znevna and 71 guests
