Brad
NAT for trusted IP
Thu Aug 13, 2009 6:20 pm
Is it possible to create a NAT that can only be used from a trusted IP or trusted range of IP's? I am needing to create a NAT for a SQL server on TCP 1433 but I don't want to open the port for the entire Internet, just from a trusted IP range where I am going to have a developer needing direct access to the port.
Thanks,
Brad
Chupaka
Re: NAT for trusted IP
Thu Aug 13, 2009 7:05 pm
use 'src-address=your_developer_address' parameter in your DST-NAT rule
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
Brad
Thu Aug 13, 2009 10:22 pm
I tried that but it didn't seem to work. Any ideas?
Thanks,
Brad
Chupaka
Thu Aug 13, 2009 11:40 pm
what exactly don't work?
Brad
Fri Aug 14, 2009 1:08 am
If I create the rule without a SRC address, I can telnet to the port. If I create it with the SRC address, I cannot telnet to the port even from the IP that is the trusted IP.
changeip
Fri Aug 14, 2009 1:14 am
paste the rule here so we can see what you entered.
Colo and Wholesale Bandwidth Available! Sales at SanDiegoBroadband dot com
Brad
Thu Aug 20, 2009 6:53 pm
add chain=dstnat action=dst-nat to-addresses=10.1.2.70 to-ports=1433 in-interface=Cox src-address=65.65.65.65 dst-address=98.98.98.98 dst-port=1433 protocol=tcp
98.98.98.98 is the static IP through the local ISP
65.65.65.65 is the IP I am attempting to trust to allow connections through from it
Users browsing this forum: Bing [Bot], guido2020, m86895, MSN [Bot], pekos, sindy, spiritcore and 101 guests
