MUM Europe 2020
antoniogc
Ipsec Problem
Mon Sep 07, 2009 12:30 pm
Good morning, I have a problem with Ipsec, is not connects mikrotik to another one, I have 2 rb532a with firm 2.9.51 with the following configuration:
192.168.36.0/24 LAN eth1(MKT1)eth2 82.X.X.1-----Internet-----82.X.X.2 eth2(MKT2)eth1 LAN 10.2.0.0/16
The data of Ipsec are:
Mikrotik1
Policy print
src-address=192.168.36.0/24:any dst-address=10.2.0.0/16:any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=82.X.X.1 sa-dst-address=82.X.X.2 proposal=default manual-sa=none dont-fragment=clear
peer print
address=82.X.X.2/32:500 secret="prueba" generate-policy=no
exchange-mode=main send-initial-contact=yes proposal-check=obey
hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0
proporsal print
name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=30m lifebytes=0 pfs-group=modp1024
Mikrotik2
Policy print
src-address=10.2.0.0/16/24:any dst-address=192.168.36.0/24:any protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes sa-src-address=82.X.X.2 sa-dst-address=82.X.X.1 proposal=default manual-sa=none dont-fragment=clear
peer print
address=82.X.X.1/32:500 secret="prueba" generate-policy=no
proporsal print
that it is what I can these doing badly?
a greeting
Krusty
Re: Ipsec Problem
Thu Sep 10, 2009 11:38 am
you have to create IPIP or EoIP tunel and make IPsec go through it
mrz
Re: Ipsec Problem
Thu Sep 10, 2009 11:54 am
There is no need to run one more tunnel, as IpSec is already configured for tunnel mode.
If you have masquerade on those routes, then make sure that you have accept rule for ipsec traffic.
Krusty
Re: Ipsec Problem
Thu Sep 10, 2009 12:14 pm
If I made IPsec only, than it dont work. Its from MT v 3, before this version IPsec works by it self
Users browsing this forum: astraliens, blajah, Chupaka, giorgi4212, Google Feedfetcher, Jeroen1000, MSN [Bot] and 79 guests
